Options to consider for the rear end - Chevelle Tech
 4Likes
  • 1 Post By 70CHEVELLE396
  • 1 Post By novadude
  • 1 Post By lheise88
  • 1 Post By big gear head
post #1 of 12 (permalink) Old Aug 1st, 16, 4:26 PM Thread Starter
Jorge
68 Chevelle with EFI 5.3L and 4L60e.
Just put the motor and trans in, and think it's smarter to get posi traction in the rear now, before my tune, so I don't have to pay for a second tune down the road when I get a new rear. Whatever's in there now works fine, but only spins the right tire.
What are some of your opinions on options to consider for a better rear end? Buy used or new? rebuild current rear? I'm green, so I appreciate the insight!
JSolo is offline
post #2 of 12 (permalink) Old Aug 1st, 16, 4:32 PM
Re: Options to consider for the rear end
Here are a couple of questions.
What rear end is currently in your car? Are you happy with the gears? Is it a posi, or open differential?
What's your intended use for the car?
What's your budget?
Do you want the rear end to come with brakes? If yes, disc or drum?
Steve R
Steve R is online now
post #3 of 12 (permalink) Old Aug 1st, 16, 5:16 PM
Freddie
Assuming that you have the 8.2 10 bolt. This can be made to hold up pretty well with a mostly stock 5.3 and a automatic transmission. I would use a Eaton Posi, Yukon Dura Grip or a Eaton Truetrac and a good set of axles. If you are changing gears then correct set up is very important. Bearing preload and contact pattern are extremely important to the strength.
If you invest a lot of money in the 10 bolt then it might make more since to just upgrade to a 12 bolt. It doesn't cost much more to build a 12 bolt. The price of the housing is the only difference. lf you plan to up the power then go for the 12 bolt.
big gear head is online now
post #4 of 12 (permalink) Old Aug 1st, 16, 6:45 PM Thread Starter
Jorge
What's your budget?
Steve R
I'm not sure what's currently in the car, but pretty sure it's not stock. All I know is that only 1 tire spins. I haven't tuned the car yet, so i can't say I'm happy with the gears because I don't really know how they'll perform when properly tuned. Intended use: daily driver.
I don't have a fixed budget, and I'm not set on discs or drums in the back. Weighing price, value, and future avoidance of issues is my focus. I've learned to handle repairs in the right order so I'm not going back and doing things twice, i.e. getting a second tune.
JSolo is offline
post #5 of 12 (permalink) Old Aug 1st, 16, 9:12 PM
Like Freddie said, you can build an 8.2 10 bolt to take some abuse but the parts will likely cost the same as it would for a 12 bolt. If you're not budget limited and you don't currently have a 12 bolt housing, look into an aftermarket 12 bolt or possibly a bolt-in 9 inch ford. The 9" inch would be great for having the ease of changing 3rd members.
Video:
fr8dog is offline
post #6 of 12 (permalink) Old Aug 1st, 16, 9:13 PM
Perhaps just buy a crate rear and be done with it. Moser, Strange, or Currie are all good. Probably looking around 3k and up depending on options.
Kirk's67SS likes this.
70CHEVELLE396 is offline
post #7 of 12 (permalink) Old Aug 1st, 16, 9:29 PM
That's a problem around here, as anyone with even a common 68-72 peg-leg 2.73 10 bolt thinks they have a rare jewel and they charge accordingly.
I've been watching, as I'd like to pick one up for my Dad's 70, and I can find anything for under $500, and even at that price, you are looking at a bare housing or junk with brackets cut off, etc. Maybe other parts of the country are different.
Having said that, you can build the 10-bolt for ~$1200, maybe less. If you factor in what you will pay for a 68-72 housing, you are probably getting up into the $1700-2000 range. I think the 10-bolt will be A-OK if you are not drag racing with sticky tires. Just my opinion.
70CHEVELLE396 likes this.
novadude is offline
post #8 of 12 (permalink) Old Aug 2nd, 16, 10:58 AM
I went with a strange s60. 35 spline axles, Trutrac, drum brakes. Ready to bolt on. 3200 bucks.
lheise88 is offline
post #9 of 12 (permalink) Old Aug 2nd, 16, 1:48 PM
Greg.
^^^ X 2 that is the way I did it to
Could not be happier
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #10 of 12 (permalink) Old Aug 2nd, 16, 5:40 PM
Freddie
I was going to get a S60 for my '67, but now I'm just trying to sell the car. I like the look of the big 60.
post #11 of 12 (permalink) Old Aug 2nd, 16, 8:12 PM
I was close to going with the S60, but wanted to retain the GM look. So a Moser 12 bolt was my choice. I started with just the housing and axle kit. Then built it out the way I wanted, with the parts I wanted. I'm sure I spent more in the end, and I'm sure ultimately the S60 is stronger. But it's the way I wanted it. I'm very happy with how it turned out.
post #12 of 12 (permalink) Old Aug 3rd, 16, 7:32 PM
If you don't mind driving a little there are always listings in the Baltimore & dc craigslists. I haven't checked in a few months but there was a guy with a peg leg 10 bolt listed forever that got down to $75 obo.
PoorMansXcuse is offline
This Thread is more than 1345 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
