new rear - oil and additive - Chevelle Tech
post #1 of 4 (permalink) Old Aug 1st, 16, 12:01 PM Thread Starter
Bull
So I did some reading on here and the 80w-90 sent for the rear seems fine. I also have the 4oz of limited slip additive.
I was all set but then read the back of the bottle (2nd pic) and it says "no special ad dative needed".
I am guessing i still add it.
thanks for insight.
ID:	377074   Click image for larger version
1969 Chevelle Malibu
73k miles
350/330 crate motor
5 spd - Legend 700
4.11 rear
Holley 4160 600cfm
Original console and bucket car
disc brakes
aluminum rad/elec fans
QA1 adjustable shock/new springs/new tubular control arms front and back / tall ball joints
Bullcrappy is offline
post #2 of 4 (permalink) Old Aug 1st, 16, 1:46 PM
Freddie
Re: new rear - oil and additive
Try it without the additive and if it pops when you turn a sharp corner then put the additive in. You don't want too much additive. It's kind of a balance between too much and not enough.
big gear head is offline
post #3 of 4 (permalink) Old Aug 1st, 16, 4:06 PM Thread Starter
Bull
Thanks Freddie, maybe I will call Moser too... I have over 3k in this rear so don't wanna chance it.
73k miles
350/330 crate motor
5 spd - Legend 700
4.11 rear
Holley 4160 600cfm
disc brakes
post #4 of 4 (permalink) Old Aug 1st, 16, 5:24 PM
Freddie
Running it without the additive will not hurt anything except your nerves. Popping and chattering clutches will not break anything. The additive just makes the clutches slip easier, which is why you don't want too much of it. You only need the additive with a clutch type differential. If you are using a Truetrac, Detroit Locker or something else that doesn't have clutches then don't use the additive.
This Thread is more than 1475 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
