10 Bolt Capabilities - Chevelle Tech
 7Likes
  • 1 Post By blue_69_malibu
  • 1 Post By Chris27
  • 1 Post By DaleM
  • 1 Post By ak 67SD
  • 1 Post By Robinls5
  • 1 Post By novadude
  • 1 Post By Andy's Auto Repair
post #1 of 12 (permalink) Old May 5th, 16, 12:19 AM Thread Starter
Ok, I've done quite a bit of research and I do know the difference between a 10 bolt and a 12 bolt with regards to strengths and features. What I want to ask is real world experience from you guys as far as your experiences with a strong 10 bolt posi setup with some horsepower behind it. I have a 65 Chevelle and trying to find a 12 bolt posi in So Cal has been close to impossible (shipping is a crazy cost from outside So Cal and 64 and 65 are particular 12 bolts due to dimensions), other than the guys that want $3000 for them. Currently I've got a mildly cammed 350 and a T350 tranny and an original peg-leg 10 bolt in there with original gearing. My future plans are a 700R tranny down the road and eventually a Mark Jones 468. I want to approach the diff and the brakes before I go any further with the motor and tranny. We have no tracks out here, so there will be zero track time. I'm not a lead foot BUT as we all know, when we have the HP, we like to show it off a bit, but I will say, I'm rolling into 50 years old and I still have a perfect driving record......I'm SURE that will go down the tubes with Mark's motor in my ride though. Sorry for the long run here but I just wanted to ask you guys if you think holding out and paying extra for a 12 bolt that I will have to have dialed in by a local shop to my specifications ($$$) or putting a posi unit and disks on my current 10 bolt and just rolling with that set up would be advantageous. Thanks for listening and I appreciate any advice!!
RaceFace is offline
post #2 of 12 (permalink) Old May 5th, 16, 12:29 AM
Re: 10 Bolt Capabilities
Here's what my rear-end builder told me last Summer when I asked what would happen if I put one of Mark's 570/580 468s in my car. (Original '69 8.2" ten bolt that has been upgraded to Moser Axles, Eaton Posi, and Yukon gears.)
On street tires and drag radials, I'm probably fine.
But, if I ever put on slicks on a prepped track and I dead hook, something may give in the rear....probably the yoke....but it could be other areas.
Take that for what it's worth. Help it helps.
Jb71SS likes this.
blue_69_malibu is offline
post #3 of 12 (permalink) Old May 5th, 16, 12:52 AM
I shattered my 8.2 behind a 388 small block on street tires. I was even trying to be nice to it, soft launch but as soon as I shifted to 2nd....BANG! No more 10 bolt. Broke the posi carrier right in half and sheared half the teeth off the ring gear. This was an eaton posi and richmond 3.73 gears. Stock everything else in the rear end. It has previously survived just fine behind a mild 350 that ran 13.30's on drag radials. 12 bolt installed shortly after and it's been trouble free for 15 years. I wouldn't waste money upgrading an 8.2, especially if there's a BBC in your future.
RaceFace likes this.
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #4 of 12 (permalink) Old May 5th, 16, 8:32 AM
Dale
A 10-bolt can be built strong but consider this; GM put a 12-bolt behind anything rated 300 HP and greater for a reason.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #5 of 12 (permalink) Old May 5th, 16, 8:38 AM
Can't say that I'd invest in the 10, I'd find any 12 casing and have it narrowed to suit, but given your description of how you're going to use it you'll probably never hook and the 10 will last. I had a stock 10 bolt 8.2 in mine, ET Streets, 4.56 gears, behind an SBC than ran 12.40s at the track. My car hooked and I ran it hard on the streets for many years and the 8.2 held up.
It would be different if you had a good known 8.2 posi already, but if you're sinking money, I'd find a 12.
ak
ak 67SD is offline
post #6 of 12 (permalink) Old May 5th, 16, 9:41 AM
I have done in my lifetime what you are doing. " Talk myself into something ". TORQUE, Will make you a beliver. As been said by others.
My 1962 Chevy had a cast iron 4 speed, ( NO torque 283) Then the Saginaws, Then the Muncies- 20s -- 21s -- 22s -- Then the Chevy 10 bolt rears, Moving along,, Then the Chevy 12 bolt rears. Horsepower is a by/product of TORQUE.
TORQUE,, Always has and Always will, Cause driveline issues.
The old Purolater commercial " Pay me now,, Or pay me later, Your are going to pay me ! "
Robinls5 is offline
post #7 of 12 (permalink) Old May 5th, 16, 9:52 AM
I am running those exact parts in my 8.2 with a girdle cover. Mine is in a 3300# (with driver) car with a 4-speed, running very similar times to what you've listed in your signature (12.9x @ 108). My car has more ET in it, but I was a little scared to launch it harder on drag radials (2.0 60' time) and I wasn't powershifting for fear of breaking something.
I've been beating on this combo on the street for a while with rock-hard all season radials. With zero track time, street tires, and an automatic you'll be fine.
blue_69_malibu likes this.
novadude is offline
post #8 of 12 (permalink) Old May 5th, 16, 9:59 AM
Andy
Maybe try to look for a later BOP 8.5 and add a little offset to the wheels. I have had a 3.73 posi 8.5 that was in one of my Chevelles when I got it. It has been sitting behind my shop for 6 months and the scrap guys ignored it. Finally put the guts in a 74 Impala. The 8.5 in my 81 Malibu has 20 mid 9 second passes on it.
Andy's Auto Repair is offline
post #9 of 12 (permalink) Old May 5th, 16, 3:30 PM Thread Starter
Yeah, I think you guys are right. Just step up and do the 12 bolt and do it right the first time. I don't want to have that sitting in the back of my mind that my diff may not be strong enough. Well, the hunt goes on. Thanks guys!!!!
RaceFace is offline
post #10 of 12 (permalink) Old May 6th, 16, 2:13 AM
While my upgraded 8.2 is fine for my purposes, I don't think everyone realizes how much stronger the 8.5 is than the 8.2. There are lots of 10 second or faster 86 & 87 Gran Nationals running the 8.5 that came with the car from the factory.....with some minor upgrades.....with zero problems and lots of bad a*s time slips.
post #11 of 12 (permalink) Old May 6th, 16, 2:20 AM
[QUOTE=novadude;8842617]I am running those exact parts in my 8.2 with a girdle cover. Mine is in a 3300# (with driver) car with a 4-speed, running very similar times to what you've listed in your signature (12.9x @ 108). My car has more ET in it, but I was a little scared to launch it harder on drag radials (2.0 60' time) and I wasn't powershifting for fear of breaking something.
QUOTE]
I only have a few tricks left up my sleeve....but I'm hoping for sub 12.7 @ 108 come the cool air of Fall.....and hopefully a Summer of no oil leaks.
I've upgraded my valve springs so that I can actually rev past 5700, have a 3" exhaust and X pipe kit from Torque Tech to install and replace the awful 2.25 pipes that came with the car, and will be switching from a 670 SA to 770 SA. I'll tune the carb, take it to a follow up dyno session....and it runs what it runs at that point.
It's never been easier, cheaper, or more fun to build a nice street 350. We'll see how long I hold out for a 383 upgrade.
post #12 of 12 (permalink) Old May 6th, 16, 9:21 AM
jeff
In stock form the 10 and 12 bolts never lasted for me .
But I hammer my stuff like a dirt track racer. and My cars pull heavy loads on trailers.
I was so happy when I finally got a 9" ford.
Now that is all I want to use.
One reason being that i have many different centersections set up ready to go with different gear ratios in them.
From 2.29 all the way to 4.56.. a bunch in the middle of these.
I only had one 8.5 it was a Posi unit and a I used it as a trailer axle.
jeff swisher is offline
This Thread is more than 1386 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
