Trans turbo 400 - Chevelle Tech
post #1 of 15 (permalink) Old Jan 30th, 16, 10:14 PM Thread Starter
Trans turbo 400
Will A turbo 400 out of the truck with short tail fit a 1970 Chevelle don't know the year just looking around just want to make sure it will bolt to the crossmember and fit
Mikeschevelle70 is offline
post #2 of 15 (permalink) Old Jan 30th, 16, 11:34 PM
Rhodson
Re: Trans turbo 400
im using a th400 w/ short tail out of an RV and put it into my 64. i just had to swap out the yoke. it was the same length as the th350 i had in there prior to the swap. hope this helps
rhodsonr702 is offline
post #3 of 15 (permalink) Old Jan 30th, 16, 11:51 PM
Re: Trans turbo 400
I have a TH400 short shaft out of a 74 1/2 ton pickup that had a 454 up front - in my 65 Elky. It replaced the Powerglide and I had to cut a couple of inches from the driveshaft - FWIW. The only mods were the new front yoke and had to move the trans crossmember back a few inches.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #4 of 15 (permalink) Old Jan 31st, 16, 11:37 AM
rick
Re: Trans turbo 400
I have an RV 454 turbo 400, it takes a bolt in yoke unless you swap out the end shaft, unless you know your way around the inside of a trans you could either take it to trans shop and have it changed, which I think since my trans is out that's what I'm going to do or get a bolt in "truck style" yoke. My body guy has a SBC S-10 that he races and he thinks that is a weak spot, you might want to think about a drive shaft safety loop also.
shovelrick is online now
post #5 of 15 (permalink) Old Jan 31st, 16, 1:52 PM
Re: Trans turbo 400
What is in it now ?
mrpaticular is online now
post #6 of 15 (permalink) Old Jan 31st, 16, 2:48 PM Thread Starter
No transmission or engine yet or front end looking at a complete 1986 454 complete with serpentine set up pan to air cleaner and I see a lot of truck Turbo 400 transmission on craigslist the rest of the car is nice just picked it up 2 weeks ago
post #7 of 15 (permalink) Old Jan 31st, 16, 5:33 PM
rick
Re: Trans turbo 400
I would look for a BBC with a roller cam already in it, retro fit cams are a bit pricey, I think SBC started using roller cams in 87? but not sure on BBC, mine is an 86 hft, taking my trans to a trans shop tomorrow to get the shaft changed, I had a drive shaft made and bought a $90 bolt in yoke so I'm in the shaft around $350, that I'm not going to use LOL. And one day hoping to change to an overdrive trans.
post #8 of 15 (permalink) Old Feb 2nd, 16, 8:56 AM
rick
Re: Trans turbo 400
if your still thinking on using the truck T-400, I took mine to a local trans shop and they wanted $300 to change the tail shaft and that was if they didn't find any other problems in the tranny?, $2000 for a built 700r4 with a corvette servo, different clutches, 2200-2500 rpm convertor, cut and redo my drive shaft, I have to buy the TV cable and new shifter and they install it, think I'm going that route so you could use the T-400 or think about something in the overdrives.
post #9 of 15 (permalink) Old Feb 2nd, 16, 1:24 PM
Re: Trans turbo 400
Before all the expense and hassle of changing the output shaft look into a TH400 front DS yoke made for his purpose. Its counterbored just for this. Bought a ready made shaft from PST with this yoke. M trans is a truck trans with the threaded hole in the end.
71 Chevelle
Mark Jones 454
Dynamic TH400
QP 9"
kaljam is offline
post #10 of 15 (permalink) Old Feb 2nd, 16, 5:24 PM
Austin
Re: Trans turbo 400
Like this one?
Transmission Slip yoke for T-400, 4L80, 4L85 truck transmission 1350 Series 32 spline
I am doing the same with a TH425 out of a RV but am wondering if there is some where else to purchase the yoke.
Edit.
They have this one in stock
SONNAX - FORGED CHROMOLY 1350 SLIP YOKE - T-400, 4L80, 4L85 Transmission Slip yoke for use on Truck Transmission 1350 Series 32 spline
Austin79 is offline
post #11 of 15 (permalink) Old Feb 2nd, 16, 8:35 PM
Re: Trans turbo 400
Yup - just like those.
71 Chevelle
Mark Jones 454
Dynamic TH400
QP 9"
kaljam is offline
post #12 of 15 (permalink) Old Feb 2nd, 16, 9:48 PM
Austin
Re: Trans turbo 400
Would changing the tail housing be needed?
Austin79 is offline
post #13 of 15 (permalink) Old Feb 3rd, 16, 1:33 AM
Re: Trans turbo 400
I didn't think a bolt-in yoke would work on a Chevelle... The driveshaft needs to slip somewhere, either the front yoke or an intermediate slip-joint...
TC #1366
Sold
Sold
1966_L78 is offline
post #14 of 15 (permalink) Old Feb 3rd, 16, 9:00 AM
rick
Re: Trans turbo 400
I didn't know anyone made that yoke, sounds like the best fix, I guess it's long enough not to fall out if the rear gets up high?
post #15 of 15 (permalink) Old Feb 3rd, 16, 1:04 PM
Re: Trans turbo 400
Check this out - shows it pretty well.
Slip Yoke - T3-3-5571HP - Sonnax
71 Chevelle
Mark Jones 454
Dynamic TH400
QP 9"
kaljam is offline
This Thread is more than 1454 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
