12 Bolt upgrade - Chevelle Tech
post #1 of 4 (permalink) Old Oct 20th, 14, 5:22 PM Thread Starter
12 Bolt upgrade
It is time to upgrade my 12 bolt rearend.
I do many street miles, always driving to/from the track, cruising and so on.
Chevelle 69 3860lbs raceready.
Transbrake 4000rpm and front wheels will see a little bit of air.
Best ET 10.63 127mph so far.
My goal is to go high 9:s, but not faster in this car.
Rearend have steel bearing caps, Eaton clutch plate posi and stock 30 spline axles with c-clip eliminators today.
I have to change the axles to better quality, but will 30 splines with c-clipeliminators and my posi be enough?
Spang is offline
post #2 of 4 (permalink) Old Oct 20th, 14, 6:05 PM
Freddie
Re: 12 Bolt upgrade
I think I'd change the differential. I'd be worried that the clutches on one side might give up and put you in the wall. That's a lot of power for a Eaton Posi. I think the Detroit Locker is a good differential for that type of use. You can get it with 33 splines.
big gear head is offline
post #3 of 4 (permalink) Old Oct 21st, 14, 6:08 PM Thread Starter
Re: 12 Bolt upgrade
I think the Detroit Locker is a good idea.
35 splines and a spool is cheaper, and will do the job at the strip.
But how is it driving around town?
Maybe i will go with 33 splines and a spool.
Then I can swap in a Detroit Locker or other posi later if I want to.
Or, is 30 splines and a spool enough in my case?
Then I have the option to go back to stock Eaton posi again.
Spang is offline
post #4 of 4 (permalink) Old Oct 21st, 14, 6:33 PM
Freddie
Re: 12 Bolt upgrade
I don't think I'd use 30 spline axles if I was running in the 9s.
This Thread is more than 2089 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
