TH400 to a 5 gear change - Chevelle Tech
post #1 of 4 (permalink) Old Oct 14th, 14, 10:56 PM Thread Starter
Lookin to put a 5 spd in a 67 Malibu, have the petals, frame is set up for a manual. Whats a great change over over kit setup? Bell housing, flywheel, clutch, Clutch fork ect. All linkage. A 5 gear that will handle a well built 396. Is there someplace that offers all the above? What tranny? Richmond?, Tremec?
Thanks dudes.
67 Malibu Transformed
tristatechevelle is offline
post #2 of 4 (permalink) Old Oct 15th, 14, 10:43 AM
Vince
Re: TH400 to a 5 gear change
Thanks dudes.
what is your budget $$$
what is you current axle ratio???
what about floor/hump mods? factory bump only or a big hole you can throw the trans thru
VinceS427bb is offline
post #3 of 4 (permalink) Old Oct 15th, 14, 10:52 PM Thread Starter
3.73 rear, ill modify the tunnel to make it work. Its all apart now. 2800, 3k?
post #4 of 4 (permalink) Old Oct 16th, 14, 12:01 AM
Vince
http://shiftsst.com/a-body-1964-1967...specifications
these links may be a good guide for what is offered as a complete kit.
http://americanpowertrain.com/p-8969...s-6-speed.html
i chose to not go this route because i wanted to reuse as many of the existing parts that i had on my 4speed car.
i also went with an early 3550tremec that was not a tko model that people have issues shifting above 6000rpm.
i think a 5speed richmond is a good choice for you as less mod's should be needed.
but new prices have jumped to $3500 just for the trans
This Thread is more than 2053 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
