1994 lincoln town car transmission cable. Hit a stump - Chevelle Tech
post #1 of 4 (permalink) Old Mar 7th, 14, 11:49 PM Thread Starter
David
1994 lincoln Town Car
On way to house I stopped to check my irrigation water and I hit a 3" diameter stump that broke my shifter cable that attaches to my transmission. Also my car will not start. (Neutral safety switch?) The cable is not attached to the transmission anymore. The cable has a long slot on it and I found a plastic clip on the ground that I assume held the cable to the car. Did this just as the sun was going down tonight. I lifted the car up and it appears I bent the transmission shift lever also. Then it got dark outside. I can straighten that out in the morning. The transmission still shifts if I move the shift lever on the transmission by hand although I cannot start the car. It appears i might have damaged the neutral safety switch also. Not sure where that is located though. Was wondering what part (s) I might need. A complete cable or the clip? that attaches the cable to the transmission. Any help would be greatly appreciated. Wanted to see if I could get a heads up so I know what I might be up to in the morning. Thanxs again. David
55 210 Chevrolet New project
64 El Camino (sold to finance new project)
67 SS Chevelle '396
69 Sanger Flat Bottom boat
77 El Camino parked daily driver
78 Z/28 Camaro, High School Car Class of 80 350'
80 Spectra 21' Mini Day cruiser Blown 454
88 IROC Camaro (sold to finance new project)
1994 fac2 dr Blazer 4x4
02 F-250 7.3L Diesel 4" lift
david_396 is offline
post #2 of 4 (permalink) Old Mar 7th, 14, 11:56 PM
Re: 1994 lincoln town car transmission cable. Hit a stump
The safety switch may be part of the shifter linkage. Late model GM vehicles have the switch on the outside of the transmission case over the selector shaft. Ford may be similar.
63 Nova wagon
Philip is offline
post #3 of 4 (permalink) Old Mar 8th, 14, 6:56 PM
rkd
Ron
Not totally sure, but a 94 Lincoln should be a 4.6 engine with a 4r70w.
Some googling shows the neutral start switch is part of the manual lever position switch located on the trans where the manual lever enters the trans. That trans should have shift linkage or cable, and a throttle valve cable, iirc.
rkd is offline
post #4 of 4 (permalink) Old Mar 8th, 14, 7:33 PM
Steve "Dirty"
Pop of the linkage and try it manually. If it is bent you will have to change it out.. Its not that hard.
68 SS427 Chevelle
5.3 LS 84mm Billet Turbo
55 Chevy Field car
"Another One Back On Jack Stands"
But you'll appreciate me soon. You're gonna be hangin' on for mercy when I get this sucker rollin'.
The internet is like the Bugs Bunny Show "AAH Could Be"
modchevelle is offline
This Thread is more than 2153 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
