Bellhousing Inspection Cover - Chevelle Tech
post #1 of 3 (permalink) Old Dec 30th, 13, 9:46 PM Thread Starter
rkd
Ron
Is the bellhousing inspection cover supposed to link to the back of the oil pan?
The one that came with my Ground Up 621 bell kit had some raised tabs in that area.
Thanks.
rkd is offline
post #2 of 3 (permalink) Old Dec 30th, 13, 10:07 PM
Re: Bellhousing Inspection Cover
Yes, those tabs hook over the lip on the pan, so the cover doesn't move in and hi the flywheel. I had to trim mine a bit to make the tabs work.
Bill Rose is offline
post #3 of 3 (permalink) Old Dec 31st, 13, 11:00 AM Thread Starter
rkd
Ron
Thanks. Will fix the tabs they were almost flat. Already hit the flywheel a bit.
rkd is offline
This Thread is more than 2350 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
