Upgrade my 12 bolt or go 9" - Chevelle Tech
post #1 of 7 (permalink) Old Feb 3rd, 13, 11:37 AM Thread Starter
Hi Guys
I've got a 68 prostreet BBC that I'm slowly working on turning into a restomod/protouring car. I will eventually go turbo LS 6 speed. My target is 600 RWHP.
That being said I need to get my rear end to be a bit more streetable. Right now I have:
12 bolt 4 link
C-clip eliminators
spool
4.56
TA girdle cover
fully welded tubes
Easiest upgrade for me would be to continue to build the 12 bolt with the following
9" axle ends
35 spline axles
wavetrac
Drop down to 3.42-3.73's for the M6
Obviously the other way to go is 9". I would have to get the 4 link stuff welded up and get the driveshaft modified. I'd probably want to go with the wavetrac in that as well.
I don't plan to drag much. If I do it will be on street tires. Thoughts?
'68 Pro-street
cbrock is offline
post #2 of 7 (permalink) Old Feb 3rd, 13, 11:41 AM
Re: Upgrade my 12 bolt or go 9"
Originally Posted by cbrock View Post
Hi Guys
12 bolt 4 link
C-clip eliminators
spool
4.56
TA girdle cover
fully welded tubes
9" axle ends
35 spline axles
wavetrac
Whatever you do get rid of the spool. Dangerous on the street.
oman is offline
post #3 of 7 (permalink) Old Feb 3rd, 13, 12:09 PM
Greg.
Dana S60 by Strange with 3.55 Rear Ratio with Trac-Loc Posi and 1350 yoke pinions .
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #4 of 7 (permalink) Old Feb 3rd, 13, 12:32 PM
Gary
i would upgrade your 12 bolt.put the new ends on ,make sure the tubes are straight and aligned and go.you need a fixture for the fab work . lots cheaper than buying a brand nerw housing and less work than modifying a 9 inch to fit the car. i run a factory 12 bolt in my low 9 sec drag car
gnicholson is online now
post #5 of 7 (permalink) Old Feb 3rd, 13, 1:44 PM
Freddie
Do the 12 bolt. You have a good plan for it.
big gear head is offline
post #6 of 7 (permalink) Old Feb 6th, 13, 1:34 PM Thread Starter
12 bolt it is. I found a nice picture on another forum where they added some back bracing to the 12 bolt axle tubes and ran a removable bar to go across the rear cover area. It looked like it could be adjust to add a little preload to the tubes.
For those of you who haven't driven a spool on the street it's really not that bad. Clearly, cars like this aren't out running in the rain or snow. The only real &@#$& is trying to parallel park. I want the car to drive like OEM but handle some serious power, something like the wavetrac seems to fit the bill.
'68 Pro-street
cbrock is offline
post #7 of 7 (permalink) Old Feb 6th, 13, 1:48 PM
Good Choice. They work fine.
Ray
bracketchev1221 is offline
This Thread is more than 2711 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
