Bellhousing out alignment - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old May 22nd, 10, 9:16 PM Thread Starter
Ric
Send a message via MSN to rbeckman
Thumbs down Re: Bellhousing out alignment
Well I can't get the dowl pins out while they are in the car, I'm going to make a couple of calls on Monday to see if I can find someone to get them out as laying on my back under the car trying is not doing it....if not I will be pulling the motor to see if I can get them out that way.
This is the worst idea I have had converting over to a 5 speed as nothing is going good and the cutting the tunnel was something I really wish I did not do now...oh well.
Ric Beckman
1969 Chevelle SS 396 5 speed.
1972 Camaro SS 350
Team Chevelle Member #2998
MY CAR
rbeckman is offline
post #17 of 20 (permalink) Old May 22nd, 10, 10:03 PM
Vince
Get a pair of vice grips and work them back and forth - the'll come out
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
post #18 of 20 (permalink) Old May 22nd, 10, 10:11 PM Thread Starter
Ric
Vince, I have tried that and can't get them from slipping...not enought metal to make contact with.
Ric Beckman
1972 Camaro SS 350
MY CAR
rbeckman is offline
post #19 of 20 (permalink) Old May 22nd, 10, 10:48 PM
Guy
A punch and a BFH will get them out
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #20 of 20 (permalink) Old May 23rd, 10, 9:42 AM
Yep I just did that yesterday. A couple whacks of the BFH and they popped out. good luck
whitey70ss is offline
Tags
bellhousing , dowl pins , keisler , tremac
This Thread is more than 3610 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
