T56 6 speed - Page 3 - Chevelle Tech
post #31 of 40 (permalink) Old Mar 29th, 09, 5:41 PM
Re: T56 6 speed
Hey crookedbowtie, how did this install turn out? I'm getting ready to install a T56 in my 70 skylark...looking for others that have done it for info/advise.
70 Skylark Convertible Pro-Touring project - LT1 w/ Lloyd Elliott cam, 11.1, 58mm TB, custom harness & tune, T56, 12-bolt w/ 4.10s
87 Iroc, ZZ4, ProTopline 220cc, cc305 w/ 1.6's, Miniram, Paxton SN2000, Raptor 700R4 w/ Vigilante 2600 stall, 3.73's, Hotchkis suspension w/ Koni adjustables, C5 brakes, 17" Centerlines
ed1le is offline
post #32 of 40 (permalink) Old Aug 27th, 09, 8:48 AM
Mako
Re: T56 6 speed
Hey with the T56, you will not want anything lower than a 3.73. With 4.11 , 1st gear wont even be there long enough to take off and shift.I would get a 3.55 or higher(numerically lower)personally. Just remember these are geared super low in first.
Sky64 likes this.
DD 1970 Chevelle "Boostelle" 02 6.0L W/ a healthy cam and a lil boost
DD 98 Blazer"Family SUV" 2000 6.0L Swap ,Small cam Family SUV
1971 Chevelle "Raven" 2002 5.3l W/alil boost
lt170chevelle is offline
post #33 of 40 (permalink) Old Aug 27th, 09, 11:11 AM
Re: T56 6 speed
The T56 doesnt have that low granny gear in first.
I have 4.11s a 27 in tall tire and love it, 1st isnt too low at all. in fact switching to a 25-26 in tall tire, should be even funner.
The TKO trannies use that low 3.27 1st gear (pretty sure) so inthat case with a low rearend gear yes its hard to use.
2.66, 1.78, 1.30, 1.00, .74, .50.
There is one yr (not sure so double check) 93??? that used a 2.97 1st gear
cuisinartvette is offline
post #34 of 40 (permalink) Old Aug 27th, 09, 12:28 PM
Re: T56 6 speed
Agree with 67T56-
I run a 3.89 gear in mine and it's bitchin'. Pulls hard off the line and delivers 20+ on the fwy in 6th. LOVE the T56!!
See my Pro Touring '67 Chevelle Wagon at:
Winner- 2011 Car Craft "Real Street Eliminator" competition
Scotch is offline
post #35 of 40 (permalink) Old Aug 27th, 09, 1:20 PM
Re: T56 6 speed
+2 on what Elky said...only 93 had the steeper first gear but it was a weaker trans. After doing research, most told me that 3.73's to 4.11's were best with the T56.
I'm going to be running 4.10's with mine. Had a TKO w/ 3.73's in my '91Z, 1st was super steep but great for hard launches, cruising around town, I started off in 2nd most of the time.
ed1le is offline
post #36 of 40 (permalink) Old Jul 31st, 11, 9:03 PM
Captain
Re: T56 6 speed
looking to put a t-56 into a 65, will there be a tunnel cut required for that as well?
Leonard Washington is offline
post #37 of 40 (permalink) Old Jul 31st, 11, 9:34 PM
jerry
Re: T56 6 speed
cheveslakr is offline
post #38 of 40 (permalink) Old Aug 1st, 11, 6:51 AM
Darren
Re: T56 6 speed
Not a 65, but you will see how much I had to remove for a 71.
https://www.chevelles.com/forums/showthread.php?t=357712
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525+++ rwhp
71454Chevelle is offline
post #39 of 40 (permalink) Old Aug 1st, 11, 12:50 PM
Matt
Re: T56 6 speed
I want a t56 so bad but man are the aftermarket ones expensive!!!
I apologize if this has already been covered but has anyone been able to run a console with the t56 in a 70-72?
402 BBC - TH400
71Avido is offline
post #40 of 40 (permalink) Old Aug 1st, 11, 4:03 PM
Captain
Re: T56 6 speed
Got it. Lots of work in a 71. I am doing a 65, and wondering if there are any "gotcha's" in the job. I don't want to get started and realize i have to cut the car in half to put the last bolt in...
Tags
6 speed , swap info , t56 swap
This Thread is more than 3175 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
