Trans Shaft Pinion Angle & the Rearends Pinion Angle - Chevelle Tech
 6Likes
post #1 of 24 (permalink) Old Jul 31st, 20, 5:56 PM Thread Starter
Greg.
Had my Racer Mechanic Measure the above for me on his Alignment Host with the Car on all 4 Wheels
Just wondering what your guys thoughts are on the Results ;
FRONT Trans Shaft Angle = 0*
What does this mean in Relation to the old thoughts of that they should be Opposite
REAR Pinion Angle = - 4* aka Pointing Down
I think this is good as when I Launch the Rearend will Rotate upwards putting the Angle at - 2* or less(-1*)
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #2 of 24 (permalink) Old Jul 31st, 20, 6:38 PM
Hey if it means anything my angles are +1 up front and -3 out back. Saying that, I have a new rear end on the way.....
71malibuu is offline
post #3 of 24 (permalink) Old Jul 31st, 20, 6:42 PM
Cody
Re: Trans Shaft Pinion Angle & the Rearends Pinion Angle
Is this the isolated angle of each component or their operating angles with relation to the driveshaft? What do you have for a transmission mount, and how old is it? I believe you want something other than 0* for an operating angle for U-joint life, otherwise the needles won't rotate.
-SS454- likes this.
1971 Monte Carlo
Blackhawk is offline
post #4 of 24 (permalink) Old Jul 31st, 20, 8:00 PM Thread Starter
Greg.
The U Joints & ALL the Rear Suspension Grease-able Poly Bushings are around 6 years old
and the Short Rubber Trans Mount was just Changed out in 2019
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #5 of 24 (permalink) Old Jul 31st, 20, 10:12 PM
Down load the Tremec tool box app to your phone, you can use it to measure the angles and it will pass/fail the setup.
RMMiller is offline
post #6 of 24 (permalink) Old Jul 31st, 20, 11:55 PM
What angle is the driveshaft at?
David Bates and -SS454- like this.
67
70 (SOLD)
Alwhite00 is offline
post #7 of 24 (permalink) Old Aug 1st, 20, 8:29 AM
^^^ This!
You need to know this to calculate the working angles which is what really matters.
-SS454- likes this.
USAF Retired (1968-1988)
David Bates is offline
post #8 of 24 (permalink) Old Aug 1st, 20, 9:55 AM
Roman
Transmissions are NEVER at 0* so why is yours? Something doesn't sound right?
sz0k30 is offline
post #9 of 24 (permalink) Old Aug 1st, 20, 8:57 PM Thread Starter
Greg.
As you know every car is different for Wheel/Tires / Space in the Tunnel for Later 4 Speed Auto Trans / etc
When I Swapped in the Short Water Pump BBC from a SBC we had to move the Frame Brackets back 1" to 2"
so there would be enough Room for the Efan SetUp and to make sure the Dist would not Rub/Hit the Firewall
So I would think Moving the Engine Rearward likely had an effect on the Angle it and the Trans sits on
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #10 of 24 (permalink) Old Yesterday, 8:33 AM
If you moved the frame mounts back 1"-2", that's going to put the distributor closer to the firewall
nitrofox is offline
post #11 of 24 (permalink) Old Yesterday, 11:21 AM Thread Starter
Greg.
Yes it did but we made sure there was enough room
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #12 of 24 (permalink) Old Yesterday, 12:42 PM
So with all this being said, isn’t it irrelevant what position the motor is in? What is The optimal driveshaft angle, pinion angle, and trans angle? I would think that the optimal number would be attainable with washers/shims/ and or brackets regardless of the motors front to rear orientation.
I personally would go +3* at the trans output side of the drive shaft,
and -3* at the rearrange pinion side of the drive shaft. I would think that if those angles are correct, actual driveshaft angle would be a byproduct. I’m sure someone with more experience could shed some more light, that’s just Makes sence to me
post #13 of 24 (permalink) Old Yesterday, 1:49 PM Thread Starter
Greg.
My understanding is the further forward the Engine is the more of a Downward Angle the Rear of it is
Therefore by moving the Engine Rearward in the Engine Bay there is less of a Downward Angle
and therefore when the Trans is attached to the Engine there is less of a angle
Another thing to Note is that Intakes are usually Higher at the Back of them so the Carb will sit Flat
because of the Engine is usually lower at the Rear/Firewall
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #14 of 24 (permalink) Old Yesterday, 3:26 PM
Measuring any angle without measuring the driveshaft is useless IMO. I've heard from so many "old school" car guys how they checked the pinion angle and that's it, not even checking the driveshaft.
Ideally the operating angles at the trans will be equal and opposite to the pinion, with a minimum of 1* to allow the U joints to rotate.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #15 of 24 (permalink) Old Yesterday, 6:57 PM
Or you could be like me and the driveshaft is running uphill to the rear end. This compounds the u joint angles and nothing you can do. You definitely need the driveshaft angle in order to see what you are up against.
67
70 (SOLD)
