Option for Pinion Angle - Chevelle Tech
post #1 of 7 (permalink) Old Jul 13th, 20, 9:02 PM Thread Starter
I have a 67 chevelle with a 496 Vortec pro that is lowered two inches and I just installed a 4l80E transmission. The Angles were to steep so I cut the tunnel and now I'm able to raise the transmission. I have a few options below and I wanted to know which you think is the best for a Strong street car with street slicks. I have SPC adjustable rear control arms with delran sockets so I'm thinking it should only need an additional 1 or 2 degrees of negative rear Pinion angle to account for the rear pinion moving upward during hard acceleration. I have put three examples setting the transmission at -1.7 and three examples for the transmission at -2.4 degrees accounting for additional negative pinion angle.
transmission tailshaft -1.7 , driveshaft -3.1, rear pinion +1.7 Goal during hard acceleration
transmission tailshaft -1.7, driveshaft -3.7, rear pinion + .7 1 degree down for acceleration
transmission tailshaft -1.7, driveshaft -4.4, rear pinion + 0 1.7 degree down for acceleration
transmission tailshaft -2.4 , driveshaft -2.8, rear pinion +2.4 Goal during hard acceleration
transmission tailshaft -2.4, driveshaft -3.0, rear pinion +1.4 1 degree down for acceleration
transmission tailshaft -2.4, driveshaft -3.3, rear pinion + .5 1.9 degree down for acceleration
So how much additional negative rear pinion would you think I need? 1 or 2 degrees?
Which example would you think would work best?
Thanks in advance for any input!
tomsheaffer is offline
post #2 of 7 (permalink) Old Jul 14th, 20, 7:09 AM Thread Starter
Re: Option for Pinion Angle
sorry my numbers got condensed in the above post.
transmission tailshaft -1.7 , driveshaft -3.1, rear pinion +1.7 ....................Goal during hard acceleration
transmission tailshaft -1.7, driveshaft -3.7, rear pinion + .7 ...................1 degree down for acceleration
transmission tailshaft -1.7, driveshaft -4.4, rear pinion + 0 ...................1.7 degree down for acceleration
transmission tailshaft -2.4 , driveshaft -2.8, rear pinion +2.4 ....................Goal during hard acceleration
transmission tailshaft -2.4, driveshaft -3.0, rear pinion +1.4 .................. 1 degree down for acceleration
transmission tailshaft -2.4, driveshaft -3.3, rear pinion + .5 ....................1.9 degree down for acceleration
post #3 of 7 (permalink) Old Jul 14th, 20, 10:17 AM
David Estes
Download the Tremec app on your phone. It works great.
Have you ever stopped to think and forgot to start again??
suprdave1 is offline
post #4 of 7 (permalink) Old Jul 14th, 20, 10:44 AM
Troy
I'm into drag racing, so just curious.
Do you need to allow for pinion gain in the four link style rear ends as opposed to a leaf spring car that allows the differential to rotate when power is applied?
Sent from my SM-T720 using Tapatalk
66 CHEVELLE
senna is online now
post #5 of 7 (permalink) Old Jul 14th, 20, 11:07 AM Thread Starter
from what I have read you should allow 1 or 2 degrees for a 4-link.
post #6 of 7 (permalink) Old Jul 14th, 20, 11:18 AM
Troy
I wonder if that changes with solid delrin style bushings vs factory style rubber bushings.
66 CHEVELLE
senna is online now
post #7 of 7 (permalink) Old Jul 15th, 20, 2:01 PM
The '91 Fox body Mustang in the picture has a 4 link with solid bushings. I set 1% down and it worked great. In a 4 link rubber bushings will compress under hard acceleration. Prior to the 1% down it had wheel hop.
Chas
Sent from my SM-G950U using Tapatalk
chasmalo is offline
