Anyone know how this compares on a GM rear end? - Chevelle Tech
 7Likes
  • 1 Post By senna
  • 1 Post By Alwhite00
  • 1 Post By big gear head
  • 2 Post By big gear head
  • 2 Post By cage2592
post #1 of 12 (permalink) Old Jul 7th, 20, 1:24 PM Thread Starter
Anyone know if there is a difference from the axle centerline to the center of the u-joint towards the front of the car between a 10/12 bolt chevy and a 9" ford? I know the ford is lower - Looking for the fore/aft dimension.
I'm just wondering if I need a new driveshaft.
67
70 (SOLD)
Alwhite00 is online now
post #2 of 12 (permalink) Old Jul 7th, 20, 1:29 PM
Troy
Re: Anyone know how this compares on a GM rear end?
Anytime the ring gear diameter is increased the centerline of the pinion is lowered.
I believe depending on the yoke used 10 an 12 bolt rear ends can use the same drive shaft.
I have no input on a Ford 9 inch.
66 CHEVELLE
senna is offline
post #3 of 12 (permalink) Old Jul 7th, 20, 1:51 PM
Troy
Speaking of drive shafts, what do you have now?
If you're still using the factory shaft with 1310 U joints and you switch to a 12 bolt, where is the weakest link now?
A drive shaft failure can be way more catastrophic than a differential failure
Just food for thought. I know that snowball just keeps getting bigger.
Kirk's67SS likes this.
66 CHEVELLE
senna is offline
post #4 of 12 (permalink) Old Jul 7th, 20, 2:08 PM Thread Starter
Just FYI - I am looking to go from a 10 bolt to a 9" and wondering if the existing driveshaft will work.
427L88 likes this.
67
70 (SOLD)
post #5 of 12 (permalink) Old Jul 7th, 20, 2:31 PM
You may have to measure yourself, or get the dimensions direct from a manufacturer of 9"s off their blueprints. Axle centerline to centerline of ujoint in yoke. Which you may have to do yourself for the GM unless someone has, and jotted it down.
PS I have a Denny's HD and "foolishly" leave greaseless 1310s in for the weak link. Safety loop for sure. And it does chew them up, esp the rear. ( which I dont have a loop for hut could easily weld one in near the mongo mufflers) !)
post #6 of 12 (permalink) Old Jul 7th, 20, 2:32 PM
Troy
I just googled it. It gets a little confusing, but could possibly work.
Are you having a rear end built or buying a used unit?
66 CHEVELLE
senna is offline
post #7 of 12 (permalink) Old Jul 7th, 20, 2:53 PM
Freddie
There are different length yokes for the 9 inch, so depending on which yoke you use, your drive shaft may be close or it may be a few inches off. I used the long car yoke for a while in mine with the stock drive shaft. It's best to measure and do the math. That way you don't get into trouble and possibly destroy your car.
big gear head is offline
post #8 of 12 (permalink) Old Jul 8th, 20, 8:51 AM
Roman
So no one knows the answer to the original question?
sz0k30 is offline
post #9 of 12 (permalink) Old Jul 8th, 20, 10:01 AM
Freddie
Even if you knew the dimension it wouldn't help a lot because of the lower pinion center line. When you lower the pinion it will increase the length required for the drive shaft. The only way to know what length of drive shaft you need is to put it together and raise the rear end to ride height and measure. http://www.strangeengineering.net/wp...Order-Form.pdf
Malibu ss 64 and Kirk's67SS like this.
post #10 of 12 (permalink) Old Jul 8th, 20, 11:38 AM
Yes Sir Freddie. On the 70 a few months ago I went from a 10 bolt to 9". 9" pinion is almost 1"inch lower and 1.25" shorter. As you stated, exact reason why I waited to measure for a new shaft after the rear install. Too many variables to just go off measurements. For example if going off just measurements would have required about 1.5-2" longer drive shaft. My 70 is lowered 3" (another reason why I like the 9" lower pinion) in the rear which moved the rear end higher in the fender well ultimately pushing my original shaft (if bolted to the rear pinion) forward towards the Trans. Also, since going with a bigger engine and the 9", I went with 1350 joints. All that combined and pinion angle set, I ordered a shaft only 5/8 longer. Stance will also play a part.
As stated by Freddie, get the rear and install. Adjust for Trans to rear pinion angles and with the car fully weighted on the floor, THEN MEASURE.
Kirk's67SS and big gear head like this.
cage2592 is offline
post #11 of 12 (permalink) Old Jul 8th, 20, 2:52 PM
Freddie
Yes, the pinion angle must be set correctly before measuring for the drive shaft. Changing the pinion angle can make a bid difference in the drive shaft length.
post #12 of 12 (permalink) Old Jul 8th, 20, 2:57 PM
Harold
depending your current trans yoke , a longer yoke might be available so original driveshaft could be retained
But due to the number of variations of Ford pinion yokes, you cannot determine this length without all installation complete and measured exactly as mentioned previously
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
