How to determine rear axle ratio? - Chevelle Tech
 3Likes
post #1 of 20 (permalink) Old Jun 6th, 20, 4:55 PM Thread Starter
Ken
Can rear axle ration be determined by these factors?
1. At 55 mph RPM is 2250
2. Engine is a ZZ4 350 V8
3. Transmission is TH350
67 Chevelle Malibu, ZZ4 350 crate engine, TH350, FiTech EFI, Vintage Air, Dakota HDX dash, FlowMaster exhaust, Digi-Tails tail lights and front marker lights, 17" Rally style wheels, Redline tires
darksky is offline
post #2 of 20 (permalink) Old Jun 6th, 20, 4:57 PM
Greg
re: How to determine rear axle ratio?
What gear are you in at 55 ? Third I'm assuming. And what is rear tire size ?
Sent from my ONEPLUS A5010 using Tapatalk
Why do they call it rush hour when nothing moves?
howsad4me is offline
post #3 of 20 (permalink) Old Jun 6th, 20, 5:51 PM
Is speedo correct?
The biggest problem facing America today is that lies are so widely accepted as truths.
Alan F is offline
post #4 of 20 (permalink) Old Jun 6th, 20, 6:02 PM
Jack
1967 Chevelle Rear Axle Codes
Gear ratios vary, but the Turbo 350 typically has a first gear ratio of 2.52 to 1.00; 1.52 to 1.00 for second; direct drive in third; and 2.07 to 1.00 in reverse.
RPM Calculator
It's better to burn out than to just fade away - Neil Young
1971 Chevelle SS 454 LS5 Clone
Jack454 is offline
post #5 of 20 (permalink) Old Jun 6th, 20, 7:27 PM
Kurt
What is your tire height ??
1966 Black/Red SS coupe .....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
13/12 4 wheel disc brakes
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #6 of 20 (permalink) Old Jun 6th, 20, 7:33 PM
Kurt
If you have 26 inch tires, you have a 3.07 ....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #7 of 20 (permalink) Old Jun 7th, 20, 1:42 AM Thread Starter
Ken
Originally Posted by Alan F View Post
Is speedo correct?
Yes
darksky is offline
post #8 of 20 (permalink) Old Jun 7th, 20, 1:44 AM Thread Starter
Ken
In third gear at 55mph. Tire size: 255-50R17
darksky is offline
post #9 of 20 (permalink) Old Jun 7th, 20, 3:09 AM
Re: How to determine rear axle ratio?
Do you have a posi rear end? If not, then use your passenger side rear wheel to determine the gear ratio in the rear. Get the rear end of the car up in the air with both rear tires off the ground safely resting the frame or the axle tubes on two jack stands with wheel chocks under the front tires to prevent the car from rolling. Either use a piece of masking tape or some white-out paint on the side of the driveshaft. You can also do the same on the passenger side rear tire as well. Shift the transmission into neutral with the emergency brake off.
Watching the mark you've placed on the driveshaft, count exactly how many turns the driveshaft makes while turning the rear wheel by and one full revolution. If the driveshaft turns 3 1/2 turns, you have 3.55 gears in the rear. If it turns a hair past 4 turns, you have 4.10 rear gears. If it's just a hair over 3 turns, you have 3.07 gears, etc. etc.
BillyGman is offline
post #10 of 20 (permalink) Old Jun 7th, 20, 6:43 AM
Kurt
Non-Posi, you raise one wheel off the ground.... Posi, both wheels ....
BillyGman likes this.
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #11 of 20 (permalink) Old Jun 7th, 20, 7:21 AM
Greg.
According to this Calculator it is a 3.36/3.31 Rearend Ratio
Speed Potential Calculator For Ring Gear And Pinion Changes
Alan F likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #12 of 20 (permalink) Old Jun 7th, 20, 11:49 AM
And if you do it non-posi, one tire off the ground, one tire fixed...you have to do two tire revolutions to get actual rear gear ratio at the driveshaft count, due to the fact you are rotating through the spider and axle side gears too, it cuts everything in half.
See this all the time where guys jack up one side, spin the tire once, get 1-1/2 turns on the driveshaft and think they only have 1.50 gears....they actually have 3.00 or 3.07/3.08 depending on what manufacturers rear axle they are using.
With the tire height calculator saying the 255/50-17 is 27" tall, and figuring 5% torque converter slip I got a rear gear about 3.07/3.08 for the OP's example.
Ericnova72 is offline
post #13 of 20 (permalink) Old Jun 7th, 20, 2:50 PM
Thanks for the correction guys.
post #14 of 20 (permalink) Old Jun 7th, 20, 3:40 PM
My 3.31's turn 2650 at 60 MPH. In the past my 3.55 turned about 2800 and my 3.73 did 3000 at 60. I suspect if you have a 10 bolt you have 3.08's and 3.07 for a 12 bolt which spin about 2400 at 60. That is with approx 26.5 tire height. Your tires are about 27.1 inches in diameter which give you lower RPM then what I stated but not a lot.
Billdini is offline
post #15 of 20 (permalink) Old Jun 7th, 20, 5:06 PM Thread Starter
Ken
OP here... Thanks for all the suggestions, but I don't have a floor jack or jack stands. Was just curious if rear end ratio could be determined with the info I provided.
darksky is offline
