m20 repair - Chevelle Tech
 5Likes
  • 2 Post By LeoP
  • 1 Post By LevonH
  • 1 Post By LeoP
  • 1 Post By Pete 67
post #1 of 13 (permalink) Old May 23rd, 20, 2:19 PM Thread Starter
Andy
m20 repair
My muncie m20 tarted popping out of 2nd and than it would just grind going into 2nd. I noticed that there was quite a gap between 1st gear and its synchro before I tore it down. When disassembling, I found the snap ring on the rear bearing of the mainshaft had broken in half and fallen off, and the mainshaft moved forward. I am wondering if any of you have seen anything like this before, what the cause may be and how to prevent this from recurring after repairs are made. The car is a 70 Chevelle with original 396 and is an original 4 speed car, although this isnt the original transmission. I have the factory trans but it has a fragged 1st gear and its an m21 which I never really liked.
thanks in advance
70 Chevelle SS396
wolf396 is offline
post #2 of 13 (permalink) Old May 23rd, 20, 10:56 PM
leo
Re: m20 repair
Andy, look up DZAUTO, aka Tom Parsons, he is a Muncie expert and is in Mustang, Okla, good luck with your trans!!
davewho1 and 71350SS like this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 13 (permalink) Old May 23rd, 20, 11:05 PM
Levon
Re: m20 repair
Paul Cangliosi at 5speeds.com is also an excellent resource.
LeoP likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #4 of 13 (permalink) Old May 24th, 20, 3:04 AM
Re: m20 repair
What did your synchros, hubs & sliders look like when you tore it apart? Was there any damage to the mainshaft?
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is online now
post #5 of 13 (permalink) Old May 24th, 20, 8:24 AM Thread Starter
Andy
Re: m20 repair
The syncros and sliders really look pretty good. No damage other than the snap ring that I have seen.
70 Chevelle SS396
wolf396 is offline
post #6 of 13 (permalink) Old May 24th, 20, 10:25 AM
Re: m20 repair
Tom did mine a year or so ago. I drove up from Dallas to deliver it to him. He did a great job.
steveleb66 is offline
post #7 of 13 (permalink) Old May 24th, 20, 12:24 PM Thread Starter
Andy
Re: m20 repair
The more I think about it and look at it, I think the snap ring was probably defective or re-used. I cant see how enough force could be pushing fwd on the main shaft to break the snap ring without causing major damage to the shaft or case. I have Paul's book and I plan to rebuild it myself. I'll probably take the gear set from the m20 and put them in the m21 case.
70 Chevelle SS396
wolf396 is offline
post #8 of 13 (permalink) Old May 24th, 20, 10:26 PM Thread Starter
Andy
Re: m20 repair
Okay, so it looks like I need an input gear and a rebuild kit to get this back together. I see d&l transmission gets recommendations so I may buy from them. Rock Auto has parts for a whole lot cheaper from USA Standard Gear, is that stuff garbage, or ok to use?
70 Chevelle SS396
wolf396 is offline
post #9 of 13 (permalink) Old May 24th, 20, 11:05 PM
leo
Re: m20 repair
For the BEST results, go with d&l or the above vendor 5speeds.com. Don't go cheap on your transmission parts and good luck with your car!!
Pete 67 likes this.
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #10 of 13 (permalink) Old May 25th, 20, 3:03 AM
Re: m20 repair
I've rebuilt two M20s in the past year with parts from Paul at 5speeds.com. Paul doesn't use a generic parts kits, he assembles the best small parts like heavy duty dimpled bronze thrust washers & higher quality syncro rings, etc. And he has his own custom designed replacement parts such as print o seal gaskets & an extended fit countershaft which is helpful for preventing oil leaks.
Plus he is the guy who literally wrote the book on rebuilding these transmissions & is active here on the forums lending his expertise. Why not buy from the source?
Don B likes this.
post #11 of 13 (permalink) Old May 25th, 20, 8:58 AM
Don
Re: m20 repair
Ditto on 5speeds,rebuilt several muncies with Pauls stuff.It's quality and if you have any questions he'll be glad to answer them for ya if ya call him.
Don B is offline
post #12 of 13 (permalink) Old May 25th, 20, 11:01 AM Thread Starter
Andy
Re: m20 repair
Okay, thats what I thought. What does everyone think of torque lock sliders? Paul Cangliosi doesn't seem to like them.
70 Chevelle SS396
wolf396 is offline
post #13 of 13 (permalink) Old May 25th, 20, 2:15 PM
Re: m20 repair
No need for them unless you have worn gear engagement teeth, IMO. If your original hubs & sliders are in good shape, you can reuse them. If not, I would look at Pauls matching zero rok assemblies. He selects matched pairs with very tight tolerances which make for smoother shifts.
