Question about selecting gear ratio - Chevelle Tech
 14Likes
  • 5 Post By Alan F
  • 1 Post By Jim Mac
  • 2 Post By big gear head
  • 1 Post By Skier_Bob
  • 3 Post By Lew540
  • 1 Post By hydro462
  • 1 Post By Alan F
post #1 of 12 (permalink) Old May 22nd, 20, 11:49 AM Thread Starter
Pete
I am thinking about getting a 12 bolt to replace the 8.2" 10 bolt I have in my 68. Currently a 3.08 open diff.
I have a mild 396 with a TH400 with 26" wheel diameter and the car is slow from a stop. I have some money but no experience on doing an engine build but a rear end swap looks like something I can do quickly so I can still enjoy the car this summer.
I was thinking of purchasing a complete rear end and thinking about what gear ratio to select. I have seen all the comments on not putting short gears in cars due to noise and high RPM on the highway. Well I live in the country and have only taken the car on the highway once. I just want something fun to drive around back roads and is quick but not fast. Again not worried at what RPM I will cruise at going 65 MPH since I rarely go anywhere with a speed limit above 45. Just want something that will be fun from a dead stop.
I was thinking at least 3.73 or maybe 4.10 with a posi would be a good choice.
bladerunner is offline
post #2 of 12 (permalink) Old May 22nd, 20, 12:03 PM
Re: Question about selecting gear ratio
Based upon your intended use a 3.73:1 would be fun. 3.31 would be practical but not enough difference from 3.08 to notice. Id stay away from a 4.10 if you do any distance at a fixed highway speed.
Protesting should not be a license for anarchy.
Alan F is offline
post #3 of 12 (permalink) Old May 22nd, 20, 12:40 PM
I've got 3.55 in my 66, 3.31 in the 70. either gears are great around town gears. jim
Kirk's67SS likes this.
70 chevelle, SS clone 454 4 speed 3.31 12 bolt posi
71 camaro. (owned since 1978!) 454-th400 3.07 12 bolt
66 chevelle 350 4 speed 3.55 12 bolt and a newly added 142 wieand blower
Jim Mac is offline
post #4 of 12 (permalink) Old May 22nd, 20, 1:14 PM
Freddie
Play around with some of these calculators and see if it helps any. Wallace Racing - Automotive Calculators
Kirk's67SS and pannetron like this.
big gear head is online now
post #5 of 12 (permalink) Old May 22nd, 20, 10:35 PM
3.73! I have 4.10 rear. think about tire size to help. shorter tire will increase rpm too.... so see if 27" or larger would work for you.
pannetron likes this.
Skier_Bob is offline
post #6 of 12 (permalink) Old May 23rd, 20, 3:45 AM
Marcus
3.55 would be my choice.
Or if you plan lot of highway driving 3.31.
What ever ratio you decide get a Us gear set imho.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #7 of 12 (permalink) Old May 23rd, 20, 8:10 AM
rick
I have a 3.73:1 posi in my 68, makes it fun around town but with 27" tall tires it's spinning about 3K rpm at around 65
shovelrick is online now
post #8 of 12 (permalink) Old May 23rd, 20, 8:57 AM
Lew
Go with a 3.73 to start (drive it this summer) and then if you want more put a Gear Vendors Overdrive on and you will have a 2.90 final drive then. Nice thing about the Gear Vendor is you keep your trans in place it bolts to the back to the Turbo 400. It comes on/off electronically or if you want to do it manually then put a dimmer switch on the floor. If you have a 3.08 now, the GV OD (with 3.73 / 2.90 OD) will be similar except about 200 rpm lower at cruising 65 mph then you are now.
bladerunner, flht01 and Kirk's67SS like this.
Lew540 is offline
post #9 of 12 (permalink) Old May 23rd, 20, 9:08 AM
A 4.10 will get you about 52 MPH at 3000 rpm, and 60 at 3500 rpm. This calculator is accurate for my car. RPM/MPH From Gear Ratio Calculator by Wallace Racing
aimhard is offline
post #10 of 12 (permalink) Old May 23rd, 20, 9:08 AM
The higher numerically you go the less torque multiplication you'll get from the torque converter.. This is where a lot of people screw up on street builds... Keep the 3:08 and change cams to something with more dig, more off idle torque. Make sure you specify "off idle torque", when looking.. There's a guy that makes cams on here that was going to make one for my 454 with tremendous low end torque..
The standard rear end differential also makes for a smoother driving and turning car... Both back wheels propel the car with this rear end its just that once one side starts spinning the power flows to that wheel.. If you learn to control rear wheel spin and install adjustable rear control arms with Delrin bushings, this makes the standard rear end the best choice..
bladerunner likes this.
hydro462 is offline
post #11 of 12 (permalink) Old May 23rd, 20, 12:10 PM
I think you might be referring to the change of rear gear to effect the stall speed of a torque converter, wherein stall speed would be lowered and the engine speed would be making less torque, however negligible, at the new stall speed. If not, would you mind elaborating on this? Thank you.
Otherwise its generally acknowledged that a higher numerical rear end ratio increases torque to the wheels. The biggest takeaway is that a change in rear gear ratio will have an effect on torque converter stall speed.
Alan F is offline
post #12 of 12 (permalink) Old May 23rd, 20, 1:26 PM Thread Starter
Pete
I was reading about a Gear Vendors OD and I think it would be a great option.
Thanks for the advice everyone. I am definitely leaning towards 3.73
