700R4 converter flush - Chevelle Tech
post #1 of 7 (permalink) Old May 16th, 20, 12:58 PM Thread Starter
Jeremy
Anyone know where I can get a converter flushed and tested? It is a lockup converter. Thanks!
69 Camaro SS Clone fully restored
496, Straub cam, 700R4, 3200 stall, Fitech Meanstreet EFI with Ahhhh... A/C,
3.42 12 bolt posi rear end
1bad69 is offline
post #2 of 7 (permalink) Old May 16th, 20, 3:57 PM
Re: 700R4 converter flush
Any local reputable transmission repair shop can and should do it. They split them around here for best cleaning of clutch fibers / metal chunkage and then re-weld the halves back together. When mine had to be done, the "neck" on it had to be replaced due to wear and the possibility of leaks.
B52bombardier1 is offline
post #3 of 7 (permalink) Old May 16th, 20, 5:48 PM Thread Starter
Jeremy
Nice. no shops around here will do it. I'm in Iowa. there used to be a shop years ago that would drill them, put them on a machine and flush and spin them. reweld them back together. They did it for $25. that was back in the 90's. Most tranny shops tell me i just need to buy another converter. Yeah. a lock up 10 inch 3200 stall converter is NOT CHEAP... i just want mine flushed and checked out. What did that run you? Before you had to have the other work done to it.
1bad69 is offline
post #4 of 7 (permalink) Old May 16th, 20, 6:06 PM
It was part of the rebuild of my 4L60E so I don't have that cost separately listed. I also kept the same stall speed as stock unlike yours.
I can ask the place what they would charge.
post #5 of 7 (permalink) Old May 18th, 20, 1:14 AM Thread Starter
Jeremy
That would be great! thanks so much!
1bad69 is offline
post #6 of 7 (permalink) Old May 18th, 20, 11:43 AM
Hello,
Call "Fred" at 318-742-7784. They will do a mail order split, clean and freshen up of your torque converter. The cost depends on how much metal they find and if you need new bearings.
https://transmissioncenter.net/
post #7 of 7 (permalink) Old May 18th, 20, 6:43 PM Thread Starter
Jeremy
Hello,
Awesome! thanks so much!
1bad69 is offline
