Gaulling oil slinger and front bearing retainer nose cone. (Steel) - Chevelle Tech
 4Likes
  • 1 Post By big gear head
  • 1 Post By 70ChevelleL34SS
  • 1 Post By 5speeds
post #1 of 10 (permalink) Old May 15th, 20, 2:15 PM Thread Starter
Frank
Hello: I have about 20 miles on a new input shaft in my 1970 Muncie M21. Checked it's lube and found it to be cloudy and contaminated with metal. Removed the trans and opened it up. Only damage I can find looks to be coming from the oil slinger gaulling with the front steel bearing retainer nose cone. Front bearing is seated properly on input shaft, nut is tight (with proper tool) and C-clip looks tight up against it. It's also the original nose cone, case, and gasket type. Question #1: Is the hole in the case, behind the bottom of the nose cone a lube drain or a supply? Question #2: If I accidentally failed to clock the nose cone properly, and the oil hole on the bottom case was not lined up with the corresponding indent on the nose cone, could this have caused an oil starvation issue? Any other ideas or suggestions as to what may have caused this? Thank you! -Frank
ID:	626778   Click image for larger version
ID:	626780   Click image for larger version
IX.XI.MMI
NEVER FORGET!
70ChevelleL34SS is offline
post #2 of 10 (permalink) Old May 15th, 20, 2:23 PM
Freddie
Re: Gaulling oil slinger and front bearing retainer nose cone. (Steel)
The front bearing retainer will only bolt on one way. The hole is a drain. There are two different gaskets that can be used on the bearing retainer. Going by memory, so this might not be 100% correct, but I think one of them is .030 thick and the other is .060 thick. You may have used the thin gasket when you needed the thick one.
70ChevelleL34SS likes this.
big gear head is offline
post #3 of 10 (permalink) Old May 15th, 20, 4:45 PM Thread Starter
Frank
Hi Freddie, I took your advice and drove to Rockland Standarrd Gear Co., they make Tranzilla. Picked up a couple new gaskets. Different thicknesses. The technician there, Mike, was very, very helpful and spent time explaining to me what you described as setting the nose cone depth. Much thanks. -Frank
big gear head likes this.
IX.XI.MMI
NEVER FORGET!
post #4 of 10 (permalink) Old May 15th, 20, 5:54 PM
Freddie
I've bought a lot of parts from Rockland Standard Gear. They know their stuff. I hope this works out for you.
LeoP likes this.
post #5 of 10 (permalink) Old May 21st, 20, 11:35 AM
Paul
usually .015 & .030 thick . I always supply both in my sets.
LeoP likes this.
Thanks,
Paul Cangialosi
( Facebook Support )
( Youtube Videos)
5speeds is offline
post #6 of 10 (permalink) Old May 22nd, 20, 9:06 AM
Cloudy fluid is usually moisture. Is there enough damage on that slinger and retainer to contaminate the fluid that much?
nitrofox is offline
post #7 of 10 (permalink) Old May 22nd, 20, 11:31 AM
leo
Maybe I'm stupid or something, but doesn't the slinger go in the inside of the trans??
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #8 of 10 (permalink) Old May 22nd, 20, 3:13 PM
Nope, that slinger/nut acts as the front seal on a Muncie
nitrofox is offline
post #9 of 10 (permalink) Old May 22nd, 20, 10:26 PM
leo
IIRC, the nut isn't a slinger and there is a left hand groove in the front bearing retainer to return the gear lube to the trans.
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #10 of 10 (permalink) Old May 23rd, 20, 10:54 AM
The left handed groove in the front bearing retainer is from an early T-10, not a Muncie...
Hope this helps... Crash
crashent is offline
