Unknown Linkage on 1969 Chevelle - Chevelle Tech
 12Likes
  • 2 Post By VinceS427bb
  • 4 Post By slowmo55ss
  • 4 Post By caminonut
  • 1 Post By caminonut
  • 1 Post By suprdave1
post #1 of 9 (permalink) Old Apr 27th, 20, 10:09 PM Thread Starter
Joel
I give up-anybody know what this linkage goes to? Still slowly pulling apart my 69 Chevelle; car is supposedly original 4 speed, but when I acquired it had an automatic in it (tranny hump was 'cut' and looked like a '66 shifter sprouting out of the floor-see below pic from the ebay ad when I bought it). Not sure what purpose this linkage would have in a manual transmission, unless someone swapped out the steering column for whatever reason. Also, here's a pic of my steering column where it goes into the steering box; is this what it's supposed to look like on an SS (my car is supposed to be an SS, but there's no build sheet and a lot of pieces were gone when I got her, I.e., holes for badges but no badges, hood, dash cluster). Thanks for the help!
ID:	624808   Click image for larger version
ID:	624810   Click image for larger version
Name:	steering knuckle.jpg
ID:	624812   Click image for larger version
post #2 of 9 (permalink) Old Apr 27th, 20, 10:37 PM
Vince
Re: Unknown Linkage on 1969 Chevelle
i suspect it is the backdrive linkage;
IIRC in 69 the cars were to be in reverse, with clutch depressed to start..
the linkage was to turn the column, to allow it to start??
i could be mistaken though...
VinceS427bb is offline
post #3 of 9 (permalink) Old Apr 27th, 20, 10:49 PM
mike
Reverse lockout linkage, to remove key from lock cylinder in reverse. Should be a bracket on frame to reverse linkage.
slowmo55ss is offline
post #4 of 9 (permalink) Old Apr 27th, 20, 11:41 PM
From the pictures you have it was a big block four speed with a bench seat.
The intermediate shaft on the steering column is for a big block Chevy.
The linkage coming off the steering column goes down to the swivel that bolts to the frame for a four-speed and you need one more rod that goes from the swivel that goes to the reverse rod on the four-speed transmission.
caminonut is offline
post #5 of 9 (permalink) Old Apr 28th, 20, 9:58 AM Thread Starter
Joel
Thanks for the help! And, thanks, John; knowing the steering column is for a big block gives me a warmer fuzzy mine is an authentic car.
Now, to find a replacement for the missing rod...
post #6 of 9 (permalink) Old Apr 28th, 20, 10:03 AM
Joel,
If you post a picture of the body tag up on top of the left corner of the cowl you will be able to find out exactly what the car was including paint code where it was built and so on, and if it's a true SS which most likely it was judging from the pictures you posted.
[email protected] likes this.
post #7 of 9 (permalink) Old Apr 28th, 20, 10:39 AM
David Estes
Contact RealRed70 he has a lot of parts and great to deal with
Have you ever stopped to think and forgot to start again??
suprdave1 is offline
post #8 of 9 (permalink) Old Apr 28th, 20, 4:25 PM Thread Starter
Joel
Originally Posted by caminonut View Post
Joel,
Thanks! Car showed up 'burgundy', but you can see the original color in places (esp. w/the fenders off & under the sil plates). Here's the body tag:
/Users/joelrush/Desktop/Screen Shot 2020-04-28 at 4.19.32 PM.png/Users/joelrush/Desktop/Screen Shot 2020-04-28 at 4.19.22 PM.png/Users/joelrush/Desktop/Screen Shot 2020-04-28 at 4.19.12 PM.png
post #9 of 9 (permalink) Old Apr 28th, 20, 4:29 PM Thread Starter
Joel
second try
Name:	Screen Shot 2020-04-28 at 4.19.32 PM.jpg
ID:	624916   Click image for larger version
Name:	Screen Shot 2020-04-28 at 4.19.22 PM.jpg
ID:	624918   Click image for larger version
Name:	Screen Shot 2020-04-28 at 4.19.12 PM.jpg
