Transmission shop - Chevelle Tech
 4Likes
  • 1 Post By 6T9 Chevelle
  • 1 Post By BillK
  • 2 Post By GuysMonteSS
post #1 of 10 (permalink) Old Apr 9th, 20, 3:42 PM Thread Starter
Rudy
Transmission shop
I have a Richmond 5 speed (4+1) installed in my 71 Chevelle. I noticed the seals by the shifting rods on the side of transmission are leaking. Called a few shops but they sounded like they don't know too much about this type of transmission. Any help would be appreciated. I live live in the lower NY area.
Rudy
71-SS396 is offline
post #2 of 10 (permalink) Old Apr 9th, 20, 4:17 PM
Is this it ?
ID:	622412   Click image for larger version
Reelysalty is offline
post #3 of 10 (permalink) Old Apr 9th, 20, 4:25 PM
Re: Transmission shop
Shift shaft seal for Nash/Richmond 4+1 are the same as a 2nd design ST-10...
Hope this helps... Crash
crashent is offline
post #4 of 10 (permalink) Old Apr 9th, 20, 4:53 PM
I don't remember if you have to split the cases or you can change them from the outside, but they're pretty easy to work on. Call Richmond and they will send you a manual or look on 5spds.com website. Paul has a youtube video on Richmonds including shifting mods.
nitrofox is offline
post #5 of 10 (permalink) Old Apr 9th, 20, 7:30 PM Thread Starter
Rudy
Thanks for the help. I will start looking now.
71-SS396 is offline
post #6 of 10 (permalink) Old Apr 9th, 20, 7:39 PM
Graham
Paul at 5speeds.com is the best. He’s very passionate about what he does and is a credit to his profession. I bought my Muncie M20 seals from him. He’s even replied to emails during the evening hours.
LeoP likes this.
6T9 Chevelle is online now
post #7 of 10 (permalink) Old Apr 9th, 20, 7:41 PM Thread Starter
Rudy
Thanks!
71-SS396 is offline
post #8 of 10 (permalink) Old Apr 9th, 20, 8:23 PM
Graham
Anytime.
post #9 of 10 (permalink) Old Apr 10th, 20, 6:53 AM
Mr Bill
Rudy,
I have found that when it comes to anything performance related it is best to ask around fellow hot rodders. There is probably a shop near you that will take on the job but it wont be your typical Aamco etc. Jody's transmissions is probably a bit far, he is in Reading Pa. He is a regular in this forum. He might know somebody in your area.
rjt427 likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #10 of 10 (permalink) Old Apr 10th, 20, 8:25 AM
Guy
I'm not sure if Brian Higgins is still working or retired,but you could call S-K speed and see if they still do transmissions.
Brian has a real good reputation when it comes to the 4+1 5 speeds.
S-K is in Lindenhurst out on Long Island NY.
https://www.skspeed.com/
Guy
Gary Anderson and LeoP like this.
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
