Anyone running a Dana 60 in a street car??? - Chevelle Tech
 13Likes
post #1 of 37 (permalink) Old Apr 3rd, 20, 7:18 PM Thread Starter
I am going to put a Dana 60 in my street car to replace the 10 bolt. What did you do for rear brakes?
454chevy is offline
post #2 of 37 (permalink) Old Apr 3rd, 20, 9:25 PM
Re: Anyone running a Dana 60 in a street car???
Well, a 12bolt is a 100%, direct swap and the entire (drum) 10bolt brake parts will swap over.
LeoP and lucifershammer like this.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #3 of 37 (permalink) Old Apr 4th, 20, 11:39 AM Thread Starter
I can build a complete Dana 60 with all new parts for way less $$ than a used 12 bolt. Plus it will be stronger.
454chevy is offline
post #4 of 37 (permalink) Old Apr 4th, 20, 12:16 PM
Troy
The " Stange S60 " is a Dana 60 cast with A body mounts.
You can buy a center section and build your own or buy a complete axle.
Being as 66 12 bolts are increasingly difficult to find, this is what I will probably do.
Sent from my SM-T720 using Tapatalk
Kirk's67SS likes this.
66 CHEVELLE
senna is online now
post #5 of 37 (permalink) Old Apr 4th, 20, 2:06 PM Thread Starter
I picked up a Dana 60 truck housing for $100. I have the bar to narrow it. Trying to figure out what drum brakes to use. I would like to use the brakes from my 10 bolt if possible. Curious what others have done.
454chevy is offline
post #6 of 37 (permalink) Old Apr 4th, 20, 3:10 PM
Greg.
I was breaking/wearing out the 12 Bolt Dif Springs every other year
so I ordered and had installed in 2013 a S60 from Strange with Ford Housing Ends H 1135
for their 11" Drum Brakes and 5 x 4 3/4" Bolt Pattern plus True Trac (Helical / worm type) Posi
Has been great on the Street, Hwy and at the Track since
See my Sig
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #7 of 37 (permalink) Old Apr 4th, 20, 3:56 PM
If going in a Chevelle what are you doing for the upper links?
67
70 (SOLD)
Alwhite00 is online now
post #8 of 37 (permalink) Old Apr 4th, 20, 4:02 PM
Claude
Yes. Here's a picture of me Dana S60 under my Buick GN. As for the brakes, they're Baers 4 wheel discs.
Claude.
ID:	621712   Click image for larger version
1971 Chevelle SS
toofastforyou is offline
post #9 of 37 (permalink) Old Apr 4th, 20, 6:29 PM Thread Starter
Claude.
Very nice
454chevy is offline
post #10 of 37 (permalink) Old Apr 4th, 20, 7:18 PM
Claude
Very nice
Thanks, I appreciateÖ but you know what's the most important to me?Ö it's the fact that it's virtrually bulletproof.
Claude.
1971 Chevelle SS
post #11 of 37 (permalink) Old Apr 4th, 20, 9:09 PM
The Dana 60 is a great choice for a rear.
454chevy, you need to remove the original truck suspension mounts and shorten the rear to the stock width of your car.
Then you need to weld on the correct brackets in the correct locations for a GM A-body triangulated suspension. A kit like this MIGHT be what you need: https://www.summitracing.com/parts/c...model/chevelle
You can search for brake kits by what the rear originally came out of: https://www.wilwood.com/BrakeKits/BrakeKitAdvisor
OR by what axle flanges you have: https://www.wilwood.com/BrakeKits/BrakeKitAxleFlange
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #12 of 37 (permalink) Old Apr 4th, 20, 10:25 PM
Freddie
How are you going to attach the upper links to the center of the housing?
If you use Moser 7900 housing ends you can use your GM brakes.
big gear head is offline
post #13 of 37 (permalink) Old Apr 4th, 20, 10:29 PM
Good luck welding them to that cast iron pig.
67
70 (SOLD)
post #14 of 37 (permalink) Old Apr 4th, 20, 10:41 PM Thread Starter
Its going in a 67 Camaro.
454chevy is offline
post #15 of 37 (permalink) Old Apr 4th, 20, 10:46 PM
Ok, that makes it a lot easier.
paul bell likes this.
67
70 (SOLD)
