New Transmission help - Chevelle Tech
 10Likes
post #1 of 23 (permalink) Old Mar 26th, 20, 8:46 PM Thread Starter
Hey All,
Can anyone recommend a website or company that sells good transmissions? Looking to buy a 700r4 and see mixed reviews for the TCI streetfigher that I was thinking of buying. Anyone have good luck with TCI or monster transmissions? As always, I appreciate all your help!
James1971 is offline
post #2 of 23 (permalink) Old Mar 26th, 20, 9:32 PM
Re: New Transmission help
Hello,
I never . . . ever . . . recommend that anybody purchase an out of town transmission. What do you do if you have a warranty claim on it? Pull it out, ship it (both at your cost and agony), they rebuild it, ship it back to you (shipping you might have to pay) and you put it back in. Who needs that kind of heartache?
Find somebody local and reputable. Ask around, there are good companies. They need your business and you need the ease of a warranty claim.
B52bombardier1 is online now
post #3 of 23 (permalink) Old Mar 26th, 20, 10:41 PM
Last year I purchased a super t10 from Summit and it failed due to improper assembly within 500 miles. They shipped me a new one while the bad tranny was still in the car and scheduled a truck to pick up the bad one. I was down for 4 days total. It's not an automatic, I know, but if you purchase through Summit and it has a warranty, they'll take good care of you. Keeping your money local is always a good thing too, if possible.
Johnny Bravo is offline
post #4 of 23 (permalink) Old Mar 27th, 20, 8:22 AM
Times 2 on Summit and Jegs !
IMO, both are textbook examples of how to run a business.
Kirk's67SS and Schwany like this.
Reelysalty is offline
post #5 of 23 (permalink) Old Mar 27th, 20, 8:44 AM
times 3 what Rick said. One trip to the drag track here, and you;d have the names of all the 700r4 gurus in town in short order. If I lived in the middle of nowhere, then I'd call Summit for "rural delivery".
PS setting up a 700R4 isnt the easiest chore due to tv cable. Nice to have local support if needed.
post #6 of 23 (permalink) Old Mar 27th, 20, 9:09 AM
autumngold
times 4,get a local rebuilder and purchase the best rebuild kit you can afford.
1970 ls-5 numbers matching
marcrose is offline
post #7 of 23 (permalink) Old Mar 27th, 20, 8:46 PM Thread Starter
Thanks all. After much research I found a local guy thats going to build one for me. I feel much better about the decision now, thanks again everyone!
post #8 of 23 (permalink) Old Mar 27th, 20, 9:45 PM
James, where are you located?
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #9 of 23 (permalink) Old Mar 28th, 20, 8:13 AM Thread Starter
Philadelphia
paul bell likes this.
post #10 of 23 (permalink) Old Mar 29th, 20, 11:03 AM
You can usually get good leads at car shows as well, but they have all been cancelled this year.
I bought a 700R4 out of town 8 years ago. I got real lucky on it lasting and still working I guess. I wouldn't have shipped it back if it failed. The company had a terrible reputation as it tuned out. I would have found a local shop to fix it if it was something I didn't feel comfortable doing myself.
Here's the only valid reason I posted even after you found somebody to build the transmission. If it is not too late one way to get rid of the TV cable adjustment scare is to have the builder put a TCI constant pressure valve body in it. They work and can save your transmission from some of the common TV cable setup errors. I have one in my 700R4, and the only negative I experienced is the build price went up.
'65 Chev El Camino
SBC350/Maybe 400HP @ crank, 700R4
Edelbrock Pro-Flo 4 4150 MPFI
'67 P-11 Norton
Schwany is offline
post #11 of 23 (permalink) Old Mar 30th, 20, 8:03 AM
No local shop would build a 4L80E for my 496. The engine builder recommended TCI, called Ondre at TCI.
I had it overbuilt, just because Ö Have about 10 k on the trans and am happy with it.
kolo is offline
post #12 of 23 (permalink) Old Mar 30th, 20, 11:14 AM
How does that valve body behave? I’m considering it but I heard it really shifts hard in all gears and especially going from Park to Drive or Reverse.
Thanks for the feedback
B52bombardier1 likes this.
yanniziomas is offline
post #13 of 23 (permalink) Old Mar 30th, 20, 1:30 PM
Originally Posted by yanniziomas View Post
How does that valve body behave? Iím considering it but I heard it really shifts hard in all gears and especially going from Park to Drive or Reverse.
It may shift too firm for a lot of people. The shifts are really quick and crisp when the transmission is freshly rebuilt with a constant pressure valve body.
It only shifts hard between gears if you set the TV cable up to shift hard. You can set it up to be soft, but I don't think it's that good for the transmission. Firm quick shifts are noticeable when trying to drive slow. When on the gas hard, it's fine IMO. My 700R4 does not shift hard from 3rd to 4th, and never has even when it was fresh. 1st, 2nd and 3rd are firm.
I think it may shift into Reverse or Drive with a noticeable bite, but I never think about it that much. I haven't lost a u-joint in 8 years, so I'm either lucky, have really good u-joints, or it might not be excessively hard, just firm.
Probably not very helpful, but that's all I got.
'65 Chev El Camino
'67 P-11 Norton
Schwany is offline
post #14 of 23 (permalink) Old Mar 30th, 20, 3:59 PM
Mark
Using a constant pressure valve body is hard on the pump. The tv cable is designed to control pressure and shift points progressively with load. By using a constant pressure vb,you will have max pressure from park to drive which can be harsh. Reverse shifts are normally at higher pressures anyway, but still may be somewhat harsh for some people. Max pressure shifts from 1-2,2-3,and 3-4 will be firmer, but this is usually acceptable in most performance vehicles. If you have the right person build and setup the transmission including tv cable operation, you don't need the constant pressure valve body. In my opinion, which is based on building and installing several of these units a year, CPVB's are a band aid at best.
modern malibu is offline
post #15 of 23 (permalink) Old Mar 30th, 20, 6:24 PM
Pugsy
Setting TV cable is simple.
First thing is the correct geometry correction piece for your brand of carburetor.
Second is to hold the throttle wide open when setting it.
IT IS NOT "ADJUSTABLE". Only set-able.
The final quick check to guarantee the setting is to pop the cable end off the carb. Push the throttle to WOT and then pull the TV cable all the way out. Bring it beside the knob it hooks to on the carb and you'll know if it's correct. It will be right beside it. Give it few snaps in and out at this point to make sure the valve is free and not hanging up. You'll feel it.
If the cable connection is back or forward of the knob it hooks on to, it's not set correctly.
Once this is correct, do not "adjust"......... Hold it, I forgot, there is one adjustment. It's the same as turning the dial on your oven full blast and walking away. Burnt.
If someone else sets it for you, pop it off, do the check above. No tools required. Trust no one.
Watch out for aftermarket TV cables. I had one that was frayed inside the sheath giving me false "feelings" as I pulled it. Toasted the tranny.
PUGSY 69 El Camino, "CURSE" 5.3 Swap, 4L60e, 3:73 Posi
6.0L cam, 4.8L Flat Tops, 243 Heads
Fun, but not fast....14.7 @ 93.2 MPH
123pugsy is offline
