Axle ratio 2.56 to 3.73 - Chevelle Tech
 12Likes
post #1 of 32 (permalink) Old Mar 24th, 20, 3:26 PM Thread Starter
Hi all,
I already know that if i want to change my 10 bolt 8.5" from 2.56 to 3.55 or 3.73 i need a series 3 carrier instead of my current series 2 carrier.
My question... does the 3 series fit in my diff housing?
Bart Fransen is offline
post #2 of 32 (permalink) Old Mar 24th, 20, 3:33 PM
Freddie
Re: Axle ratio 2.56 to 3.73
Yes.
blue_69_malibu likes this.
big gear head is offline
post #3 of 32 (permalink) Old Mar 24th, 20, 4:23 PM Thread Starter
Originally Posted by big gear head View Post
Yes.
Do i need to modify anything with spacers or will it just fit in
post #4 of 32 (permalink) Old Mar 24th, 20, 6:21 PM
Freddie
You will need the pinion and differential shims to set the pinion depth, bearing preload and backlash, but if you use a 3 series differential you will not need any other spacers.
post #5 of 32 (permalink) Old Mar 25th, 20, 5:54 AM Thread Starter
Ok i think i understand. But to be more sure.
What is exactly a carrier
What is exactly a differential
I would like to sketch a scenario.
My car has the 10 bolt 8.5" with carrier type 2 and 2.56 ratio.
If i find any gm axle 10 bolt 8.5" maybe from 1977 or so with a carrier 3 and 3.73 ratio can i take out the guts of this axle and put it in my axle?
post #6 of 32 (permalink) Old Mar 25th, 20, 6:41 AM
Freddie
Yes. Just be sure that it has the same axle splines as what you have now. You have 28 spline axles. In '89 or '90 the 8.5 rear ends were upgraded to 30 spline axles.
The carrier and differential are the same thing. I don't understand why it's called a carrier. I guess because the ring gear bolts to it, but it's actually a differential.
post #7 of 32 (permalink) Old Mar 25th, 20, 7:45 AM Thread Starter
Oke I see, and my 28 spline shafts will not fit a series 3 carrier for a 30 spline.
Perfect
post #8 of 32 (permalink) Old Mar 25th, 20, 10:44 AM
You can also change the first gear ratios to something lower.. The 2.56 with a 1:1 high gear is an excellent highway combo.. I like it better then overdrive since the driveshaft isn't spinning so fast..
1966_L78 likes this.
hydro462 is offline
post #9 of 32 (permalink) Old Mar 25th, 20, 11:57 AM Thread Starter
Last year i put in a 700r4 with lockup iy runs around 2000rpm or so at 65 mph.
Since this year in the netherlands the max speed went down to 55mph.
And i like to gain some pulling force in stead of fuel economy.
I run a 400sbc with minor upgrades. I think max 250hp or so
hydro462 likes this.
post #10 of 32 (permalink) Old Mar 25th, 20, 1:12 PM
I mean this in the nicest way possible: are you having a professional do this?
I ask b/c you don't just pull one set of gears out and then put a new set in. There is a LOT more work/time involved.....and professionals are way better at it then shade tree mechanics.
davewho1 and Kirk's67SS like this.
blue_69_malibu is offline
post #11 of 32 (permalink) Old Mar 25th, 20, 1:33 PM Thread Starter
I really appriciate you tell me this before it would have give it a go.
However indeed a specialist would do this job and not myself.
The specialist i talked with, already had doubts about second hand parts.
Whats are your opinions regarding second hand parts swapping
post #12 of 32 (permalink) Old Mar 25th, 20, 2:28 PM
Freddie
It's much more difficult to set up a used set of gears than it is a new set. Used gears don't give a clear contact pattern and it's very hard to tell when you have the pinion depth set correctly. New gears are much easier to read. A used differential is not as much of a problem, and if it's in good condition then there isn't any problem with using one. Bearings should always be replaced.
hydro462 and Kirk's67SS like this.
post #13 of 32 (permalink) Old Mar 25th, 20, 2:31 PM
I buy the best, NEW, hecho en USA, rear-end parts that I can afford...and then let a pro do it.
Other than wanting everything in the rear end to work right, you want to avoid having the gears whine.
What you're up against is that the potential cost savings from saving used parts is much, much less than having to go back to a pro should this rear end fail....and then buy more used/new parts.
You also don't know how many miles are on used rear end parts and what kind of life they led.
Kirk's67SS likes this.
post #14 of 32 (permalink) Old Mar 25th, 20, 3:23 PM
I just had my 12 bolt done they removed the 4.33 and installed US Gear pinion and gear 3.73 also new axles and bearings thruout better safe than sorry buying new and not having to do again next season
blue_69_malibu and Kirk's67SS like this.
Bradco is online now
post #15 of 32 (permalink) Old Mar 27th, 20, 7:52 AM
Hi all,
They also sell a thick ring gear set, that allows you to mount 3 series gears on a 2 series carrier. They sell a spacer as well, but those aren't really that durable.
Diabel1969 is offline
