Whining noise in 4 speed or rearend - Chevelle Tech
 5Likes
post #1 of 16 (permalink) Old Mar 24th, 20, 12:40 PM Thread Starter
Was working on my Dads 67 chevelle this morning while off of work for the virus. Did some minor tuning and took it for a spin. Its a 4 speed car, M20 and once I got up to speed I noticed a whine at cruise when you hit the throttle a little. Sounds like it is coming from the tranny. Could be from the rearend, but dont think so. Car ****s good and appears to be ok with the shifter and linkage. Clutch engages 1/2 off the floor somewhat. The whine is very similar to the one you get from a M22 as you go through the gearbox. Only does it when you hit the throttle at cruise a little. Goes away if your not on the throttle. Is this a bearing going out?
Aaron is offline
post #2 of 16 (permalink) Old Mar 24th, 20, 12:45 PM
Re: Whining noise in 4 speed or rearend
If the whinning isn't very loud, and is somewhat faint, it might be the driveshaft. Does the car have an aluminum driveshafy by any chance? I had a couple of them on other cars that did that. It's just the nature of the beast with some aftermarket driveshafts.
Were the rear end gears recently changed?
BillyGman is offline
post #3 of 16 (permalink) Old Mar 24th, 20, 12:48 PM Thread Starter
It has the original driveshaft from another 67 in it. New 1330 joints too. They have about 30,000 miles on it as does the tranny.
No, the rear gears at 3:55's. Been there for about 30,000 miles.
The whole driveline has about 30,000 miles on it. Motor has about 15,000 on it.
Aaron is offline
post #4 of 16 (permalink) Old Mar 24th, 20, 12:56 PM
autumngold
Input shaft bearing or pinion bearing.
1970 ls-5 numbers matching
marcrose is offline
post #5 of 16 (permalink) Old Mar 24th, 20, 12:56 PM
Check the level of the trans gear oil
67ss4spd is offline
post #6 of 16 (permalink) Old Mar 24th, 20, 1:01 PM Thread Starter
Have thought about this.
Aaron is offline
post #7 of 16 (permalink) Old Mar 24th, 20, 1:02 PM Thread Starter
I topped it off last oil change and the car has probably has less than 5,000 miles since this was done. It has been sitting though, but floor is dry.
Will double check it though.
Aaron is offline
post #8 of 16 (permalink) Old Mar 24th, 20, 9:50 PM Thread Starter
If I need Munice parts...where may I get them these days?
My original builder of the tranny is no longer in the business.
Aaron is offline
post #9 of 16 (permalink) Old Mar 25th, 20, 2:42 PM
pete
In no particular order:
https://www.5speeds.com
https://www.4speedconversions.com
New Products | Autogear
No endorsement, just info.
Pete
Aaron likes this.
japete92 is offline
post #10 of 16 (permalink) Old Mar 26th, 20, 7:06 AM
Tyler
We overhaul diffs all the time and from your description it sounds like a classic ring and pinion whine. Typically a bearing noise will not come and go with throttle. That being said bearing wear can be the cause of the ring and pinion whine if the carrier or pinion has loosened up and altered the contact pattern.
Chebell is offline
post #11 of 16 (permalink) Old Mar 26th, 20, 8:05 AM
Glen
Does it go away in 4th gear?
427L88 likes this.
1968 Chevelle
468 Big Block
Muncie M20 4 Speed
12 Bolt Posi 3.31:1 Gears
glend123 is offline
post #12 of 16 (permalink) Old Mar 26th, 20, 9:54 AM Thread Starter
Pete
Thanks Pete!
Aaron is offline
post #13 of 16 (permalink) Old Mar 26th, 20, 9:57 AM Thread Starter
Tyler, had guy that can fix either problem ride in it yesterday and he thinks its the pinion bearing, so we will see when he puts it on the rack.
I thought the sound was coming from the tranny....
What does bearing replacement cost?
427L88 likes this.
Aaron is offline
post #14 of 16 (permalink) Old Mar 26th, 20, 9:59 AM Thread Starter
No, you get some whine are you go up through the gears and a faint whine at cruise, but it becomes louder if you step on the throttle some at cruise, you really notice it then.
Aaron is offline
post #15 of 16 (permalink) Old Mar 26th, 20, 10:34 AM
I used to sinter my 1310 ujoints like this. Ujoints or pinion ( ouch) bearing.
