Missing drive gear - Chevelle Tech
  • 1 Post By Alan F
post #1 of 10 (permalink) Old Feb 19th, 20, 2:56 PM Thread Starter
Missing drive gear
Ok yíall, I am installing a sb350 and th350 in my 65 Chevelle and the transmission I got was missing the entire speedometer housing and drive gear. It is a BOP TH350. I understand there are speedometer calculators available online but the ones I have found are all based on the drive gear. Where do I start? Iím running 255/40/18 in the rear and have 3.36 stock rear end.
Thanks in advance.
Jacob
1965 Chevelle Malibu SS
Jakedub79 is offline
post #2 of 10 (permalink) Old Feb 19th, 20, 6:56 PM
Jon N.
Re: Missing drive gear
transmissioncenter.net/shop/speedometer-gear-calculator
They also sell the gears.
Jon N.
dyno jonn is offline
post #3 of 10 (permalink) Old Feb 19th, 20, 9:37 PM Thread Starter
Thank you, but again they are requiring a drive gear to calculate the speedometer gear, I donít have a drive gear.
Jacob
post #4 of 10 (permalink) Old Feb 19th, 20, 9:53 PM
So, pick one.
Name:	Screenshot_20200219-185104_Samsung Internet_1582167219552.jpg
Johnny Bravo is offline
post #5 of 10 (permalink) Old Feb 19th, 20, 10:22 PM
Gear ratio X 20.2 (static factor) divided by the tire diameter equals the speedo ratio.
3.36:1 rear axle ratio and a 26.0" tire will give you 2.610.
Drive gears for a T350 are in the range of 7-10 and driven gears are 17-25. Take the driven gear over the drive gear which gives you a ratio. The correct ratio will be the closest number to 2.610 in your case.
So take the 2.610 ratio and multiply it times the various driven gear ratios, then round to the closest whole integer, like below.
2.61 x 7=18.27/18=1.015
2.61 x 8= 20.88/21=99.43
2.61 x 9= 23.41/23=1.018
2.61 x 10=26.10/26=1.001
The closest combination to 1 is a 10/26 ratio. But the 26 tooth gear is not available.
The next closest is the 7/18 combination.
Pioneer4x4 likes this.
I donít like being manipulated!
Alan F is offline
post #6 of 10 (permalink) Old Feb 20th, 20, 12:02 PM Thread Starter
Awesome information, thank you. It appears that the drive/driven gears for my non bullet style GM/BOP th350 are quite different in the number of teeth, same math apply?
Jacob
post #7 of 10 (permalink) Old Feb 20th, 20, 12:25 PM Thread Starter
Ok so hereís what it got -
2.61 x 15 = 39.15/39 = 1.0038
2.61 x 17 = 44.37/44 = 1.0084
2.61 x 18 = 46.98/47 = 0.9995
2.61 x 19 = 49.59/50 = 0.9918
Looking at eBay it doesnít appear that 47 or 50 exist so my best case is 15/39?
Jacob
post #8 of 10 (permalink) Old Feb 20th, 20, 1:09 PM
I hope you know that you're also going to need an adapter for the BOP trans to Chevy engine as they don't match up.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #9 of 10 (permalink) Old Feb 24th, 20, 10:30 AM Thread Starter
Adaptor to the block or to the driveline? Itís all installed currently, without one to my knowledge.
Jacob
post #10 of 10 (permalink) Old Feb 24th, 20, 12:45 PM
Randy
To the block. Post a pic of what you have.
Randy
TC # 5401
67 Project SS Clone
pnugene is online now
