10 holy bop to 10 bolt Chevy u joint needed. - Chevelle Tech
 3Likes
  • 1 Post By Alwhite00
  • 2 Post By Alwhite00
post #1 of 8 (permalink) Old Jan 17th, 20, 10:35 AM Thread Starter
Ok. My 67 had a BOP 10 bolt and I swapped it for Chevy 10 bolt. Now the u joint on the driveshaft will not work. What number u joint is the BOP and what is the Chevy?
67
70 (SOLD)
Alwhite00 is online now
post #2 of 8 (permalink) Old Jan 17th, 20, 11:08 AM
Claude
Re: 10 holy bop to 10 bolt Chevy u joint needed.
I dunno about the u-joint but… what's the use of swapping a 10 bolt for another 10 bolt?? … I don't get it.
Claude.
1971 Chevelle SS
toofastforyou is offline
post #3 of 8 (permalink) Old Jan 17th, 20, 11:12 AM
& Administrator
https://www.google.com/search?client...ersion+u-joint
Mike is offline
post #4 of 8 (permalink) Old Jan 17th, 20, 11:26 AM
Claude.
The BOP 10 bolt is stronger than the Chevy, the only advantage is if you gained a posi.
oldcutlass is offline
post #5 of 8 (permalink) Old Jan 17th, 20, 11:44 AM
Freddie
BOP is probably a 3R and the Chevy will be a 1310. BOP is a stronger rear end.
big gear head is offline
post #6 of 8 (permalink) Old Jan 17th, 20, 12:54 PM Thread Starter
Thank you for the input. (Good or bad)
I’m just trying to get this thing on the road for the first time in 9 years. I know there are stronger rear ends. This is what I have and just trying to use what I have.
I guess I could buy a custom rear end that fits the u-joint. 😀
Kirk's67SS likes this.
67
70 (SOLD)
post #7 of 8 (permalink) Old Jan 17th, 20, 3:40 PM
Harold
3-3130 Neapco will put a 3R to a 1310. The pinion yoke will use inside snap rings to retain u joint in yoke. If it has tabs , get some measurements
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #8 of 8 (permalink) Old Jan 17th, 20, 5:43 PM Thread Starter
I found a ujoint at Napa today. Gave him my measurements and he pulled one off the shelf.
LeoP and Kirk's67SS like this.
67
70 (SOLD)
