repairing a housing?
694 views 9 replies 6 participants last post by  driveshaft-texas
when someone cuts the ears on a differential, is there a fix for it?
#2 ·
I was thinking a U bolt to hold the bushing. drill thru the boss or drill and tap? jim
#6 ·
no weld, just hope someone made a U cap pr something by now. jim
#9 ·
I bought a chevelle rear for my nova a few years ago. seller cut the eyes installed the correct multi spring perches and looking at it, it looked like a factory F body 12 bolt.
I could just install camaro perches and trade it to a camaro, firebird, nova guy. jim
#10 ·
Center housing might be ductile cast iron , or cast steel. Either case , its weldable. I have never tried to solve a problem such as you have , my only experience is welding the tubes to the center section , and it doesn't act like cast iron then. Cast iron is weldabe , but procedure is critical. It will break just beyond the weld without proper preheat and heat control and stress relief
