Auburn limited slip - Chevelle Tech
 12Likes
post #1 of 19 (permalink) Old Nov 18th, 19, 2:30 PM Thread Starter
Kurt
Auburn limited slip
Any of you guys using one of these ??
1966 Black/Red SS coupe .....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
13/12 4 wheel disc brakes
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #2 of 19 (permalink) Old Nov 18th, 19, 3:43 PM
Re: Auburn limited slip
Using one in my 10 bolt, no complaints so far, have 11k miles on it.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #3 of 19 (permalink) Old Nov 18th, 19, 5:37 PM
Freddie
If you are thinking of buying one I'd like to recommend using something else. The Auburn is probably the worst differential available.
big gear head is online now
post #4 of 19 (permalink) Old Nov 18th, 19, 5:47 PM
Some people will just have to learn the hard way.
Auburn
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #5 of 19 (permalink) Old Nov 18th, 19, 5:50 PM Thread Starter
Kurt
Hmmmm ..... ok ..... I am also considering an Eaton Truetrac ....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #6 of 19 (permalink) Old Nov 18th, 19, 5:57 PM
Lance
Eaton TrueTrac....this is a beast of a different color....well thought out, very few problems noted..would be an excellent choice in MHO
Kirk's67SS likes this.
vortec710 is offline
post #7 of 19 (permalink) Old Nov 18th, 19, 6:01 PM
I need to retract my former statement.. Looked back at my thread, running an Eaton diff. Not many options for the 8.2". Sorry for the misinformation.
Ran an auburn in a S10, never really had posi..
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #8 of 19 (permalink) Old Nov 18th, 19, 6:08 PM
Kurt, I have the truetrack in my 87 Monte Carlo SS.This is a prostreet car, 548 big block & 4L80E,Ford 9" with 4:56 gears with a truetrack setup. I had an auburn in it prior and it only lasted about 4000 miles.I'm running mickey thompson pro-street rubber approx. 15x32,hooks pretty good at the track and drives nice on the street.My first set-up was a Detroit locker,boy was that an adventure to drive on the street.I recommend the truetrack,very good all around and strong also. Good luck, Tom..
thebeast likes this.
sstom66 is offline
post #9 of 19 (permalink) Old Nov 18th, 19, 6:19 PM
Beth
Strange claims their S-Trac is stronger than the tru-trac.
Just in case anyone is looking at a S60.
nashville beth is offline
post #10 of 19 (permalink) Old Nov 18th, 19, 8:01 PM
Freddie
Which rear end do you have?
post #11 of 19 (permalink) Old Nov 18th, 19, 8:05 PM Thread Starter
Kurt
An open 3.7....... 12 bolt ....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #12 of 19 (permalink) Old Nov 18th, 19, 8:24 PM
Freddie
Then you have a lot of choices. The Eaton Posi, Eaton Truetrac, Yukon Dura Grip, Detroit Locker and several others. No need to drop all the way down to an Auburn.
LeoP, Kirk's67SS and fr8dog like this.
post #13 of 19 (permalink) Old Nov 18th, 19, 11:04 PM
Vince
my auburn lasted about 400-miles and 9-passes down the track
it exploded in my 12bolt
VinceS427bb is offline
post #14 of 19 (permalink) Old Nov 19th, 19, 9:33 AM
Little tidbit of info for anyone unaware.
GM put Truetracs in Z28s for a good while. They had a normal duty truetrac, then a type R for the SS camaros. S10 guys were buying up the takeout truetracs from SLP when they replaced them with the "R" version when turning them into SS. I bought and used 2, they work very well unless you're running autocross.
They use helical gears instead of springs/clutches. Nothing to immediately wear out and positive axle engagement like a locker.
vortec710 likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #15 of 19 (permalink) Old Nov 19th, 19, 5:04 PM
Freddie
GM used the Torsen, not the Truetrac. It's basically the same thing, just a different company. SLP also used the Torsen.
