Can you help identify this Carrier? - Chevelle Tech
post #1 of 24 (permalink) Old Nov 2nd, 19, 5:26 PM Thread Starter
Well kind of an odd situation. 66 axel housing, build date matches car build date. CE code so thatís a 3.08 posi. Has original tag on fill plug. Gears have been changed to Richmond 3.55. Now the odd. Itís an open rear. Date stamped on carrier is in line with axel build date.
Can you identify? Has it been modified? Thanks
ID:	606882   Click image for larger version
ID:	606884   Click image for larger version
Jim_66SS is offline
post #2 of 24 (permalink) Old Nov 2nd, 19, 9:01 PM
Freddie
Re: Can you help identify this Carrier?
I've seen those before, but I don't know who made them. It's a limited slip differential, but might be worn out.
big gear head is offline
post #3 of 24 (permalink) Old Nov 2nd, 19, 9:16 PM
Daryl
Looks like a bizzario unit that Pontiac used in the mid 60's. Have run across a couple of them. Cone type and the ones I saw were worn out. It was possible to machine off the end of the cone to get it to go deeper in the carrier and then shim up spring pack to get it to hold. With all the aftermarket options out there now I think it would make a good door stop if it doesn't work. Otherwise........ it could be worth some dough to someone looking for such a beast.
1970 Chevelle 505 640hp/625tq 700R4 with 2.84 gearset plus more goodies! Moser 12 bolt 33 spline axles Fitech Meanstreet fuel injection
77sonic is offline
post #4 of 24 (permalink) Old Nov 2nd, 19, 9:47 PM Thread Starter
Everything Iíve found on this 66 327 chevelle is original as far as date codes and part numbers except the engine has been replaced and the rear gear change. As I mention everything matches except the change to a Richmond gear change. Correct posi tag, correct axel assembly stamp, correct axel casting number, correct axels, backing plates, and drums.
It appears the gear change was made in summer of1997. For the carrier to have not come from the factory, someone would have have to found a date correct donor.
I think I will research how to rebuild it. Would Pontiac have had a carrier that would fit a Chevy 10 bolt?
Jim_66SS is offline
post #5 of 24 (permalink) Old Nov 2nd, 19, 11:02 PM
Pontiac had two different 8.2" cone type posi units, a two pinion light duty and 4-pinion heavy duty (I've only seen in 1970 units) which were not meant to be rebuilt but a skilled machinist could resurface the cones and carrier halves and then make hardened shims to fit between the cones and side gears to achieve proper side gear/pinion gear back lash. Here's a couple of photos of a 1970 4-pinion unit I have apart on my bench:
ID:	606930   Click image for larger version
hydro462 likes this.
USAF Retired (1968-1988)
David Bates is offline
post #6 of 24 (permalink) Old Nov 2nd, 19, 11:13 PM
Daryl
You are correct!! Upon further investigation (and looking at some parts in the shop) I found some parts from the carrier in question. It had small diameter springs (4 of them) and 4 eared clutch plates. Don't remember what it came out of. I bought all the posi rearends out of a salvage yard that was bailing everything when they were closing up.
Thanks for catching my blunder. My bad info was taking this way off track!
77sonic is offline
post #7 of 24 (permalink) Old Nov 2nd, 19, 11:39 PM Thread Starter
Question Re: Can you help identify this Carrier?
So it looks like it may or may not be original to my car as a guy may have swapped a date correct non working bizzario unit into the car. Why not just use a eaton open unit. Well it works as is and appears to be non-rebuilable. I guess I will have to decide if I want a Eaton posi unit or not.
Jim_66SS is offline
post #8 of 24 (permalink) Old Nov 3rd, 19, 12:03 AM
Daryl
Here are the plates-clutches I am thinking of. Still not sure if these are of the same unit.
I am not being much help, am I?
77sonic is offline
post #9 of 24 (permalink) Old Nov 3rd, 19, 12:05 AM
Freddie
That Pontiac unit is a Borg Warner, and was also used by Buick and Olds. I've rebuilt several of them. Not a big deal if you have a lathe and some skill. It's not the same as this 12 bolt unit.
post #10 of 24 (permalink) Old Nov 4th, 19, 8:36 AM Thread Starter
Thanks for the help Guys. Someone may have change the carrier over the years or could production have run short and they stuck a BOP carrier in a Chevelle? Getting ready for Winter in MN Daryl, I am here in Lake City, MN.
Jim_66SS is offline
post #11 of 24 (permalink) Old Nov 4th, 19, 8:45 AM
Freddie
The Borg Warner unit will not fit the Chevy rear end. If I get a chance today I'll try to get some information on this differential.
post #12 of 24 (permalink) Old Nov 4th, 19, 9:11 AM Thread Starter
Did a little searching this morning. Found the original patent filed Feb 4, 1960 by invented Loren J O'brien. Patent # 2966076 casted into the end of housing. Also casted into the end was 033290 I think and what looks like a small circle with an A inside the circle, followed by a 1, followed by kind of a oval stamp
Jim_66SS is offline
post #13 of 24 (permalink) Old Nov 5th, 19, 8:52 PM
C2 Corvette!
post #14 of 24 (permalink) Old Nov 6th, 19, 10:01 AM Thread Starter
Thanks everyone, I will now have to talk to a few corvette guys.
Jim_66SS is offline
post #15 of 24 (permalink) Old Nov 6th, 19, 10:37 AM
Freddie
The Corvette differential is split through the center with bolts that hold the 2 halves together. This one is not split.
