4-spd vs 5-spd - Page 3 - Chevelle Tech
 22Likes
post #31 of 42 (permalink) Old Oct 22nd, 19, 1:42 PM
blm
Re: 4-spd vs 5-spd
There is a mod that can be done to the case of the Tremec transmission that is supposed to make it able to be installed without having to cut the trans tunnel. There may even be info about the case modification on Silver Sports website. Probably can get better info about it from site members that have that done than you could from Silver Sport.
blm is online now
post #32 of 42 (permalink) Old Oct 22nd, 19, 2:22 PM
Pat
Re: 4-spd vs 5-spd
As I posted my TKO600 from Silver Sport needed no tunnel mods, they trim the case down and it fit as advertised. They were great to deal with.
Pats70ss is offline
post #33 of 42 (permalink) Old Oct 22nd, 19, 2:32 PM
Re: 4-spd vs 5-spd
I'd rather have 3.23s, a wide ratio four speed, a big motor with a smooth ideling street camshaft profile on a wide lobe separation 112-114. No higher than 9 on compression, 8.75 would be best...
hydro462 is offline
post #34 of 42 (permalink) Old Oct 22nd, 19, 4:05 PM
kevin
Re: 4-spd vs 5-spd
big block car with power down low? switch to 3.08 rear gear. small block car with that 450hp up high? switch rear to 3.42. Sounds like you have your Muncie all set up to go....it is a relatively easy swap on a 68-72 - especially the clutch junk... jmho....
the heckler is offline
post #35 of 42 (permalink) Old Oct 22nd, 19, 5:52 PM Thread Starter
Shawn
Re: 4-spd vs 5-spd
I've got a Blueprint 355, dyno sheet said 425 hp/tq, take it with a grain of salt I suppose, but that's what I'll tell you if you ask ;-)
Mel0Yel068
Mel0Yel068 is offline
post #36 of 42 (permalink) Old Oct 23rd, 19, 1:41 AM
Re: 4-spd vs 5-spd
Originally Posted by big gear head View Post
Yes, the factory drive shaft causes problems many time when using an overdrive transmission with low gears in the rear end. The drive shaft spins too fast and causes a vibration through the whole car.
I used the factory driveshaft in my 68 when I installed my TKO. I had it shortened to fit the new combo and I have yet to experience any vibrations at any speed. Granted the OEM shaft was in excellent condition and I took the time to check the driveline angles when I installed the transmission. Eventually I want to build a new driveshaft, but the OEM piece worked to get the car on the road for PowerTour.
dell72 is offline
post #37 of 42 (permalink) Old Oct 23rd, 19, 10:49 AM
Re: 4-spd vs 5-spd
I have an M22 auburn gear trans with 3.73:1 rear, same tires you have.
Sometimes I wish I had overdrive, but, it sure is fun on the street.
My take on the 5 or 6 speeds is, shift, shift, shift, shift, shiftshiftshiftshsaeie[jaf'l;k AHHHH!
With a bunch of torque you don't need a bunch of gears.
If you want better gas mileage and cruise speeds, get a 6 cyll Nova. just sayin
the heckler likes this.
#1104
1969 Chevelle 460, 3.73 posi
Auto Gear Super Case with M22 gears
12.11 @108 mph
Top speed 114.23
SS_Dave is offline
post #38 of 42 (permalink) Old Oct 23rd, 19, 11:12 AM Thread Starter
Shawn
Re: 4-spd vs 5-spd
I hear ya and the probability of highway travel its relatively low, so I'm inclined to run the M20. I live in the NE, which means winter is 6 months long, I don't get to put a ton of miles on my car every year. Fuel economy is not at the top of my list by any means, it's the 2800 rpm just to cruise the two-lanes that's making me hesitant. The cheapest way to remedy would be to just swap out the rear gear set for something taller, something to make the 60mph more tolerable.
If I'd just hit the jackpot, I'd have the bank to sort out a plan and do everything front to back all at once and not have to revert a change I just made haha.
Mel0Yel068
post #39 of 42 (permalink) Old Oct 23rd, 19, 12:54 PM
Freddie
Re: 4-spd vs 5-spd
Is that an Autogear M22? I haven't heard of a Auburn transmission.
big gear head is offline
post #40 of 42 (permalink) Old Oct 23rd, 19, 3:22 PM
blm
Re: 4-spd vs 5-spd
That doesn't really make sense. With a 5 or 6 speed one has basically the same gear ratios 1 through 4 as a 4 speed transmission so if fact it should be the exact same amount of shifting . The 4th gear ratio on a 5 or 6 speed trans is 1:1. The 4th gear ratio on a 4 speed transmission is 1:1
The difference is out on the highway with an overdrive transmission one has the option of shifting to another gear where the ratio is less than 1:1. With an overdrive transmission one could choose to never shift beyond fourth gear, In that case it would be identical to having a 4 speed transmission.
Pats70ss likes this.
blm is online now
post #41 of 42 (permalink) Old Oct 23rd, 19, 4:53 PM
Re: 4-spd vs 5-spd
Originally Posted by tacomatrd View Post
I thought I replied to this.. But I may try to richen it up to 14 like yours is. I currently run 14.8 which might be why it surges below 1800. I doubt it though, the cam is relatively large.
What is your total timing at cruise. I was having to richen mine up to mid 13 until I hooked up a vac source to the distr. at have it running 45* at steady cruise around 2500. Now I can run mid 14 but that is about it.
anix is offline
post #42 of 42 (permalink) Old Oct 23rd, 19, 7:12 PM
Re: 4-spd vs 5-spd
mine is around 42(35 total with 7 vac) at cruise, as a matter of fact I haven't thought about checking at 1800 or so. I have all my timing come in at 2700, so it may be lower.
I will try going to 14.3 and lower my total advance rpm...Love efi makes it easy to do that.
tacomatrd is offline
