Noise on my 70 with new muncie - Page 2 - Chevelle Tech
 11Likes
post #16 of 37 (permalink) Old Oct 17th, 19, 4:22 PM Thread Starter
Re: Noise on my 70 with new muncie
I meant higher speed.
Tmiller is offline
post #17 of 37 (permalink) Old Oct 17th, 19, 4:27 PM Thread Starter
Originally Posted by JF74chevelle View Post
Check driveline angles.
Ok. Next on my list.
Tmiller is offline
post #18 of 37 (permalink) Old Oct 17th, 19, 4:58 PM
Mr Bill
I just looked at the flywheel you bought and it is not for a 454 BUT . . . in your original post you said that you had it balanced to match the flexplate you had on the engine with the TH400 ? Correct ? If that is the case it should be fine.
So . . . . .
If you dont have a vibration in neutral then it is probably not the flywheel or clutch. Most likely the driveshaft or something else from the transmission back.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #19 of 37 (permalink) Old Oct 17th, 19, 6:07 PM Thread Starter
Thanks for that. Yes I had it balanced as you stated. Driveshaft is off and being checked for balance. I hope that is the case. We will see I will post when I have it back on. Also will check the driveangle.
Tmiller is offline
post #20 of 37 (permalink) Old Oct 17th, 19, 6:36 PM
I am confused. You keep talking about balancing the clutch to a flexplate. Flex plates are for automatics and I assume you are calling your SFI rated flywheel that you bought which BTW is for an internally balanced small block. The 400 SBC and 454 BB use an externally balanced flywheels so if you are using the part number Summit 700180 on a 400 or 454 its wrong. Am I missing something here?
71350SS likes this.
Billdini is online now
post #21 of 37 (permalink) Old Oct 17th, 19, 9:42 PM
I doubt the driveshaft is out of balance, unless it is bent. Was it in the car before? More likely the angles are incorrect causing vibration.
-SS454- likes this.
1969 SS396 Convertible
Bob Tiley is offline
post #22 of 37 (permalink) Old Oct 18th, 19, 12:55 AM
Is the driveshaft a " 3-R " shaft?
Robinls5 is offline
post #23 of 37 (permalink) Old Oct 18th, 19, 1:48 AM
Graham
Why would the driveline angle need checking if he has a Muncie installed on a factory crossmember and the rear end installed in the factory location? Did I miss something? Curious...
6T9 Chevelle is offline
post #24 of 37 (permalink) Old Oct 18th, 19, 2:47 AM
Justin
Car could be lowered or raised changing angles. I just threw the thought out there as something to check
JF74chevelle is offline
post #25 of 37 (permalink) Old Oct 18th, 19, 7:23 AM
If that part # is correct , you have an INTERNAL BALANCE flywheel , whereas a 454 is EXTERNALLY balanced meaning it literally has a slug of metal bolted to the wheel. If that is true, the vibration ought be there always.
Driveshafts out of balance usually feel like it at 55-60 mph.
-SS454- likes this.
post #26 of 37 (permalink) Old Oct 18th, 19, 7:35 PM
Didn't read all the replies, but, some things to think about..
Gene is right on with the flywheel.
If that is true, it could be bad news.
My engine builder balanced the rotating mass together.
That means the crank, rods, pistons and flywheel and harmonic balancer. He did drill the flywheel some.
Hopefully,
its the pressure plate out of balance, which is a long shot,
or the bushing in the end of the crank for the trans pilot shaft is missing or the wrong size.
If the flywheel was not bolted squarely with the crank flange, it would vibrate like crazy.
If the pressure plate were not fitting flat on the flywheel, it would vibrate like crazy.
If the bushing in the end of the tail stock for the drive shaft were wrong, worn out or missing, it would allow the driveshaft to run out.
Check your tranny mount for excessive play. you should have put a new one in there.
Do you have the wrong harmonic balancer on there?
When you find the problem, please post the solution.
#1104
1969 Chevelle 460, 3.73 posi
Auto Gear Super Case with M22 gears
12.11 @108 mph
Top speed 114.23
SS_Dave is offline
post #27 of 37 (permalink) Old Oct 19th, 19, 10:31 AM
Mr Bill
Bill,
I am pretty sure what he meant was that he had the new flywheel and clutch assembly balanced to match the flexplate that he was using with the automatic. This actually is a completely normal operation especially if the flexplate was modified in any way during the original engine balancing.
Like I stated before if he is not feeling the vibration when running the engine in neutral then the problem is not in the engine/flywheel/clutch.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #28 of 37 (permalink) Old Oct 19th, 19, 11:26 AM
Bill,
Thanks Bill. I have always been an internally balanced guy but even then I always balanced clutch and flywheel with the rest of the rotating assembly. Didn't know you could balance a 30 pound flywheel and put it in balance using a much lighter flex plate. Live and learn.
post #29 of 37 (permalink) Old Oct 19th, 19, 4:53 PM Thread Starter
Bill, you are correct. That is what I had done,however Iím reading some post alluding to the fact I might have installed the wrong flywheel. The driveshaft was out of balance. Iíve reinstalled and no low speed( mph) vibration. I do have vibration at the higher speeds aron 60-70 mph. Also the noise when I release the clutch is there but only after car has warmed up. Shifts perfectly. I might have to pull the whole thing. The noise points to a input bearing on the m22 but it has less than 100 miles on it. Donít ant to change the bearing until I find out why it failed
Tmiller is offline
post #30 of 37 (permalink) Old Oct 19th, 19, 4:58 PM Thread Starter
Iím playing stupid here. Not sure what a 3-r shaft is. Itís a shaft where the tube is larger for the main length than the ends. Iím sure itís the original.
Tmiller is offline
