Th 400 - Chevelle Tech
  • 1 Post By Tommy the Cat
post #1 of 11 (permalink) Old Oct 15th, 19, 11:09 PM Thread Starter
Th 400
I need some help!! Got my Camino back from the muffler shop the other day. When I got it home it was leaking trans fluid. So the other day I change the pan and gasket. Drove it around the block the transmission was leaking again! So I jack it up and it's leaking from the center of the yoke I have had this car for 30 years and never seen it do this any help would be awesome.
Reds5772 is offline
post #2 of 11 (permalink) Old Oct 15th, 19, 11:17 PM
terry
Re: Th 400
I believe there is a casting hole in the center of the yoke that is filled with a plastic resin. If the resin gets brittle, it will break and fall out. Used to be common to weld the hole up, I have done it without removing the driveshaft, but it would be easier...
mytmouz is offline
post #3 of 11 (permalink) Old Oct 16th, 19, 3:07 AM
Re: Th 400
what terry said.
post #4 of 11 (permalink) Old Oct 16th, 19, 10:00 AM
Re: Th 400
Interesting note about TH400 output shafts- they all started out as four wheel drive shafts and were then cut down to length for the application.
Has nothing to do with anything really, but I think it's an interesting anecdote.
Carry on.
hydro462 likes this.
70 Camino...Roller
Tommy the Cat is offline
post #5 of 11 (permalink) Old Oct 16th, 19, 11:30 AM
Jon N.
Re: Th 400
On some turbo 400's, like on my 67, an o ring was used on the output shaft to seal where the yoke slid over that o ring. With so many transmissions being replaced over the years, or rebuilt with different parts, it's hard to say whether all of the parts match the application they are being used for.
dyno jonn is offline
post #6 of 11 (permalink) Old Oct 16th, 19, 3:31 PM
Harold
Re: Th 400
Carry on.
not sure that is accurate... 400s appeared in 67 in GMs big cars and larger ci cars like our Chevelles. Not sure when the PU had it but by 1970 with the 402 was the first I remember. 4wd s were all short but the short tail 2wd was the same as 4wd in the 80s. Not important to this post but FYI
To the point , all slip yokes have a plug , like a freeze plug , in the end to seal the hole. Necessary because a broach is pushed thru to cut the splines full length. Some leak if there is no internal seal on the output shaft to stop the ATF from wicking down the splines . JB weld will work to fix in place if its CLEAN. Otherwise its best to weld it
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #7 of 11 (permalink) Old Oct 16th, 19, 3:53 PM
Re: Th 400
I was told the by a Pontiac Oakland club researcher that the Turbo 400 was ready to go in 1957 but copyright issues held it up..
hydro462 is offline
post #8 of 11 (permalink) Old Oct 16th, 19, 4:28 PM
Re: Th 400
Harold I'll have to go through my library and see where I read that. Now that you mention it, it may have a qualifier like "after this year" or something. TH400s actually went into cars in 1964 but I think Jeep used them in 4WDs first in 1965 with Buick engines so I may be missing part of the facts. I do know that the early TH400s that were mated to AMC engines had a bellhousing adapter. The later ones of course had AMC pattern bellhousings. Pretty sure all the Jeep stuff had an odd output spline count also, now that I think about it. Clearly there's more to my story!
70 Camino...Roller
post #9 of 11 (permalink) Old Oct 16th, 19, 5:21 PM
Re: Th 400
I had one of those plugs pop out of my 69 SS396 4 speed's yoke.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #10 of 11 (permalink) Old Oct 16th, 19, 5:55 PM
Re: Th 400
Weld the hole up and be done with it...
oldcutlass is offline
post #11 of 11 (permalink) Old Oct 16th, 19, 8:11 PM Thread Starter
Thanks guys the same thing I thought but wanted to make sure. You guys rock!
Reds5772 is offline
