Anyone here ever run a powerglide and a gear vendor OD unit? - Chevelle Tech
post #1 of 10 (permalink) Old Oct 2nd, 19, 9:09 PM Thread Starter
Just curious, and would love to hear opinions from those who have used the combination.
Bronze68 is offline
post #2 of 10 (permalink) Old Oct 2nd, 19, 10:04 PM
Re: Anyone here ever run a powerglide and a gear vendor OD unit?
A lot of Power Tour guys do. You can build a shorty 'Glide with Vendor that is the same length as a TH400. Seems like a pretty awesome setup to me, but no, I've never driven one.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 10 (permalink) Old Oct 3rd, 19, 9:08 AM
Never had one but agree that it sounds like a great plan..
hydro462 is offline
post #4 of 10 (permalink) Old Oct 3rd, 19, 10:56 AM
Assuming stock 1st gear ratio (v8 glide), the math says:
1.76-1.37-1.00-.78
First over(1.37) to third(1.00) would be a touch tricky, hitting the button and shifting the lever manually at the same time. Or you could leave it in OD and go straight to .78.
SSJohn is offline
post #5 of 10 (permalink) Old Oct 3rd, 19, 9:46 PM Thread Starter
I was sort of thinking the same thing. Especially as I'm going to use a horseshoe, and there's no real good way to put the button on that. I'd end up with the dimmer switch on the floor and I just don't think it's going to be comfortable/coordinated that way.
Another question: has anyone used a GV with a manual valve body? I have run a manually shifted TH400 for years, and was kind of hoping to stay with the manual shift (and reverse pattern).
Bronze68 is offline
post #6 of 10 (permalink) Old Oct 3rd, 19, 11:12 PM
Since the GV is independent of the transmission itself, it really doesn't matter if you have a reverse pattern or a manual valve body.
oldcutlass is offline
post #7 of 10 (permalink) Old Oct 4th, 19, 12:15 AM
a lot of guys on drag week/race week events run glides and GV
1968 Beaumont
502 big block
HP and ET not determined yet!
GoFast Beaumont is offline
post #8 of 10 (permalink) Old Oct 18th, 19, 2:33 PM
Why go through the expense of Gear Vendors. Just put a 400 in it and run less rear. I was running 3.42 rear, starting off in 2nd gear and running 1.70 60' times. Reality, I could've dropped rear ratio by 20%.
Status: Car-Less
GRN69CHV is offline
post #9 of 10 (permalink) Old Oct 19th, 19, 10:28 AM
Lew
I guess what kind of car is it and what are you trying to do with it. A street car you need a steeper gear off the line so I would agree with guy above maybe do a T400. IF race car and you just want that extra gear to do some cruising then I could see that. I have a T400 with a GV and it works great and I am a street car 540 CID with some trips to the track (3.73 12 bolt with GV goes to a 2.90).
Lew540 is offline
post #10 of 10 (permalink) Old Oct 19th, 19, 11:11 AM
I had one of those Shiftworks detent gates in my old horseshoe and it worked nicely. I did have to modify it a little..
hydro462 is offline
