66 backup light switch & bracket - Chevelle Tech
post #1 of 27 (permalink) Old Sep 19th, 19, 1:30 PM Thread Starter
john
I did a search on how to install the rear light backup switch and I couldn't find one. I looked in the assembly manual I have its not clear on how to install it. Anybody walk me through it would be a big help.
johnny5 is offline
post #2 of 27 (permalink) Old Sep 19th, 19, 5:37 PM
Re: 66 backup light switch & bracket
Automatic or 4 speed?
66 Malibu
busterwivell is offline
post #3 of 27 (permalink) Old Sep 20th, 19, 12:26 AM Thread Starter
john
It's a 4 speed Muncie.
johnny5 is offline
post #4 of 27 (permalink) Old Sep 20th, 19, 9:38 AM
If you want, I'll get a picture of the switch installed on my 4 speed to get you started. Let me know and I'll put it up on my lift for a shot.
66 Malibu
post #5 of 27 (permalink) Old Sep 20th, 19, 10:03 AM Thread Starter
john
Okay sounds good thanks.
johnny5 is offline
post #6 of 27 (permalink) Old Sep 20th, 19, 11:53 AM
I took a couple of pictures. Send me a PM with your e-mail address so I can forward them. I don't know how to post them here.
66 Malibu
post #7 of 27 (permalink) Old Sep 22nd, 19, 10:25 AM
pictures sent
66 Malibu
post #8 of 27 (permalink) Old Sep 22nd, 19, 11:18 AM
Bruce
Here is the new installation on my 66. I tried to do this per the AIM. My body is off the chassis making photos from a different angle easy.
ID:	603942   Click image for larger version
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is offline
post #9 of 27 (permalink) Old Sep 28th, 19, 12:31 PM Thread Starter
john
Thanks again everyone great pictures. I have another problem the American wire kit I have the plug is different on the end of it. Do they have a adapter for this, I searched the bag from the kit and there's none that match.
johnny5 is offline
post #10 of 27 (permalink) Old Sep 28th, 19, 12:51 PM
Bruce
Your switch connector is correct. I don't recognize the other two photos. Look in your assembly instructions on page M20 A9. You need harness 2988879 that connects to your underdash harness and goes the .92 dia hole in the firewall. This harness will mate with your switch.
My Build Thread:
AZCamino is offline
post #11 of 27 (permalink) Old Sep 28th, 19, 12:56 PM Thread Starter
john
The pictures on the right are from the under dash American auto wire kit. So I would need to get a adapter for this then.
johnny5 is offline
post #12 of 27 (permalink) Old Sep 28th, 19, 1:27 PM
Bruce
Was your car originally a 4 speed car? Does your original harness have this adapter/extension still attached?
My Build Thread:
AZCamino is offline
post #13 of 27 (permalink) Old Sep 28th, 19, 1:29 PM Thread Starter
john
No it was a automatic car I changed it to a 4 speed.
johnny5 is offline
post #14 of 27 (permalink) Old Sep 28th, 19, 2:25 PM
Bruce
This looks like what you need. Summit has it.RESTOPARTS®️ Supplied Backup Light Switch Extension Harnesses 10665
$33.99
My Build Thread:
AZCamino is offline
post #15 of 27 (permalink) Old Sep 28th, 19, 5:42 PM
blm
John,
This will work. The bracket mounts on the stop bolt on the aft part of the shifter and the reverse lever closes the switch when trans is shifted into reverse which completes the circuit. One terminal connects to the pink wire and the other terminal connects to the green wire at the base of the steering column. Just need to run those two wires. No harness needed.
https://www.summitracing.com/parts/huu-2480003
boyd66k20 likes this.
blm is online now
