Truck bellhousing - Chevelle Tech
 3Likes
  • 1 Post By davewho1
  • 1 Post By anix
  • 1 Post By DZAUTO
post #1 of 13 (permalink) Old Sep 16th, 19, 8:02 PM Thread Starter
Truck bellhousing
How many of you are running a truck bell housing with a muncie or T10. I know you can replace the the bearing retainer with one that fit the truck BH or they make an adapter. anyone had any luck with either??? thanks
anix is offline
post #2 of 13 (permalink) Old Sep 16th, 19, 9:03 PM
I’m using it one on mine. Not many miles on the set up yet, but no issues either. I bought a spacer and attached it with a few Allen key set screws.
Team Chevelle Member (20 years and counting...
72soft-top is online now
post #3 of 13 (permalink) Old Sep 16th, 19, 10:15 PM
Devin
Re: Truck bellhousing
I ran one forever ago before I bought a Lakewood. The early ones designed for the SM420 have the same front register as a Muncie, and I presume most other car 4 speeds. The later bells designed for the SM465 have a larger opening in them which I understand that thereís an adapter for. I didnít have any problem with mine.
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #4 of 13 (permalink) Old Sep 16th, 19, 10:26 PM
I switched from a cast iron bell housing to an aluminum one in my 57 Chevy. The tranny was a Saginaw 4-speed, so I needed an adapter that I got from a company specializing in 4 wheel drive conversions. It worked well, with no issues (until that tranny detonated).
Sent from my iPad using Tapatalk
Frank69 is offline
post #5 of 13 (permalink) Old Sep 17th, 19, 7:48 AM Thread Starter
Originally Posted by 72soft-top View Post
Iím using it one on mine. Not many miles on the set up yet, but no issues either. I bought a spacer and attached it with a few Allen key set screws.
Do you have the spacer ring and how do the set screws come in to play?
anix is offline
post #6 of 13 (permalink) Old Sep 17th, 19, 12:25 PM
This sticky up above in this forum might be helpful if you haven't read it:
https://www.chevelles.com/forums/33-...ls-photos.html
anix likes this.
David
davewho1 is offline
post #7 of 13 (permalink) Old Sep 17th, 19, 1:28 PM Thread Starter
Yes I have read it. Just wonder though....I don't guess the adapter ring posses any issue with indexing or do you need to be concerned with indexing a factory bell housing?????
davewho1 likes this.
anix is offline
post #8 of 13 (permalink) Old Sep 17th, 19, 1:46 PM
Originally Posted by anix View Post
yes i have read it. Just wonder though....i don't guess the adapter ring posses any issue with indexing or do you need to be concerned with indexing a factory bell housing?????
@dzauto ?
David
davewho1 is offline
post #9 of 13 (permalink) Old Sep 17th, 19, 2:19 PM
David
I thought the input shaft was longer also on the M465?
later, dozer
"Look Stock and carry a Big Block"
Raube Wan
dozerhand is offline
post #10 of 13 (permalink) Old Sep 17th, 19, 7:49 PM
You need to drill 3 or 4 8-32 Allen head set screws to hold the spacer to the Muncie
post #11 of 13 (permalink) Old Sep 17th, 19, 9:06 PM
I had a bunch of pictures of bell housings, adapter rings, Muncie front bearing retainers for truck housings, all on Photobucket. But they have done the final rape of our stored pictures, and UNFORTUNATELY, I did not put the same pictures on the hard drive. Thus, I no longer have all those pictures available.
I'll see what I can find-----------------if anything.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #12 of 13 (permalink) Old Sep 17th, 19, 9:24 PM Thread Starter
I have seen your pictures and it was great info. Was just wondering about the set screws....would like to see how they were used.
anix is offline
post #13 of 13 (permalink) Old Sep 18th, 19, 12:03 AM
Sorry, Photobucket has blurred the stored pictures is you don't pay their ransom. Apparently they have done this to EVERYONE's stored pictures. Sorry!
I fully understand paying a fee to upload more pictures, but it is asinine for them to prevent already stored pictures from being seen.
Anyway, this is a picture of a truck housing, a regular Muncie front bearing retainer and an adapter ring.
To assure the adapter ring stays in place around the bearing retainer, you simply drill 3-4 holes around the perimeter of the adapter ring. Then use an 8-32 tap to make threads in the holes and use 8-32 Allen head set screws to secure the adapter ring. Too easy.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
