What is the gear ratio and if it’s a Posi - Chevelle Tech
 10Likes
  • 2 Post By Kjames
  • 1 Post By Hotwire
  • 5 Post By 1966_L78
  • 1 Post By 427L88
post #1 of 11 (permalink) Old Sep 1st, 19, 4:00 PM Thread Starter
3969278nf I have this differential and it looks like it’s from a Chevelle 70 - 72 but I don’t know the gear ratio or whether it’s a Posi. It has KDC344 1 and CON2 and GM52 it also has the numbers from 1 2 3 4 5 6 7 8 9 0 on it but I don’t know what that means can you tell me what the ratio is and posi?
Peggles0224 is offline
post #2 of 11 (permalink) Old Sep 1st, 19, 4:27 PM
Al
Re: What is the gear ratio and if itís a Posi
I think it's originally a 71 273 open rear end build in Buffalo NY. https://www.chevellestuff.net/1971/rear_axle.htm
344 means it was built on the 344th day of the year.
3969278nf is the casting number that comes back to a 12 bolt rearend.
Can't help with the rest of the numbers.
Spin one axel and watch the other. If they both spin in the same direction it's a posi. If they spin in opposite directions its an open diff.
Steve R likes this.
DUTCH MAX HEADWORK is offline
post #3 of 11 (permalink) Old Sep 1st, 19, 9:26 PM
Keith
Easiest way is break it open (it can probably use some fresh oil anyways) and find the stampings on it and look at the numbers, find the separate ones (example 41-12) and divide them, that will give you the gear ratio, the carrier will have 2 springs if it’s a posi
Steve R and LeoP like this.
Kjames is offline
post #4 of 11 (permalink) Old Sep 2nd, 19, 8:55 PM
[QUOTE=Kjames;11136600]Easiest way is break it open (it can probably use some fresh oil anyways) and find the stampings on it and look at the numbers, find the separate ones (example 41-12) and divide them, that will give you the gear ratio, the carrier will have 4 springs if itís a posi[/QUOTE]
Just a fyi!
USAF Retired (1968-1988)
David Bates is offline
post #5 of 11 (permalink) Old Sep 3rd, 19, 10:08 AM
Re: What is the gear ratio and if it’s a Posi
If you don't want to break it open mark the yoke and block one axle so it doesn't spin. Rotate the other axle exactly 2 times and watch the # of turns the yoke makes.
2 3/4 turns = 2.73
3 turns, 3.08
3 1/4 turns, 3.23, etc.
I don't know chevelle ratios that well so I may be off.
427L88 likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is online now
post #6 of 11 (permalink) Old Sep 3rd, 19, 2:18 PM
Weldon
I'm not knowledgeable about 12 bolts rears, but, when I opened the rear end of my El Camino with a 10 bolt, posi unit, the ratio, 3.36, was stamped in the ring gear edge.
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
2011 Harley Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
post #7 of 11 (permalink) Old Sep 4th, 19, 3:00 AM
One thing to be aware of, is that with these assemblies being 48+ years old, they have often been altered from the original configuration... So even if the codes indicate a certain ratio and positraction, your really need to verify by either spinning/counting or pulling the cover...
I have seen many people buy rearends, Muncies and engine assemblies based on codes of seller's info, only to later be disappointed when things aren't as the were thought to be, and usually in a less desireable configuration.
TC #1366
Sold
Sold
1966_L78 is offline
post #8 of 11 (permalink) Old Sep 11th, 19, 12:24 PM
George
Mine isn't listed... The first 2 characters on my 12 bolt is CC
It reads CCW 102431
spaceace77084 is offline
post #9 of 11 (permalink) Old Sep 11th, 19, 4:53 PM
Jack
Standard ratio for 1970's was 3.31...Both manual and automatic...
For 1971/1972...Manual 3.31 ...Turbo 400...2.73
It's better to burn out than to just fade away - Neil Young
1971 Chevelle SS 454 LS5
Jack454 is offline
post #10 of 11 (permalink) Old Sep 11th, 19, 5:12 PM
Peggles, the original gearing wil be stamped on the forward part of the pass side axle, near the wheel end. For a list of those visit www.chevellestuff.com Mine, for eg, is a 1967 and stamped CF.
Hotwire has the quick and dirty method of checking ratios. Best way is to pop the inspection cover and count gear teeth, and then simple divide ring by pinion. Also gives you a visual inspection of the gearset.
Hotwire likes this.
post #11 of 11 (permalink) Old Sep 11th, 19, 5:15 PM
It reads CCW 102431
I happened to pull up 1969 @ www.chevellestuff.com , and CC code is 3.73 , the W means built in Warren MI.
