Started t56 magnum swap on 2nd gen camaro - Chevelle Tech
 4Likes
  • 1 Post By tacomatrd
post #1 of 13 (permalink) Old Aug 24th, 19, 7:37 PM Thread Starter
Well it's finally stated. Got the th400 pretty much out. Just need to lower it but it shouldn't take much longer.
Interior and exhaust are out.
Spark plugs are out so I'm ready to dial indicate the bell housing as that'll be the next step. Fingers crossed its within spec.
tacomatrd is offline
post #2 of 13 (permalink) Old Aug 24th, 19, 8:51 PM
J
Re: Started t56 magnum swap on 2nd gen camaro
Nice! Iím getting ready to take on a magnum swap soon so Iíll be following your progress. Have you decided on bell, clutch, hydraulics yet?
NorCal-SS is online now
post #3 of 13 (permalink) Old Aug 24th, 19, 9:41 PM
Troy
What's the common thought on the fit of T56 into a 2nd gen Camaro, obviously they still weren't using huge transmissions in the early 70's. And, you've taken the interior out so you plan on modifications?
I put a T56 (working on) into a 66 Chevelle and did quite a bit of tunnel modification to get a good fit.
66 CHEVELLE
senna is offline
post #4 of 13 (permalink) Old Aug 24th, 19, 11:40 PM Thread Starter
Originally Posted by NorCal-SS View Post
Nice! I’m getting ready to take on a magnum swap soon so I’ll be following your progress. Have you decided on bell, clutch, hydraulics yet?
Yes I went with a QuickTime housing
McLeod master cylinder #139310(Making my own mount bracket)
Ls1 slave
Sst clutch trk+
post #5 of 13 (permalink) Old Aug 24th, 19, 11:49 PM Thread Starter
Definitely not the modifications chevelles have to have but I will need to cut a place for the shifter and most of the top of the transmission(about a 5x12 inch hole.
I took it out so it's easier to work on for the most part
post #6 of 13 (permalink) Old Aug 25th, 19, 2:59 PM Thread Starter
More progress. Hope to dial indicate next weekend and hopefully start getting the tranny in.
ID:	601502   Click image for larger version
ID:	601504   Click image for larger version
NorCal-SS likes this.
post #7 of 13 (permalink) Old Aug 25th, 19, 3:39 PM
Beth
Taco,
What flywheel is that ? I need an internally balanced one for a BBC going in my 67 Chevelle/ T56.
nashville beth is offline
post #8 of 13 (permalink) Old Aug 25th, 19, 4:12 PM Thread Starter
Originally Posted by nashville beth View Post
Taco,
It's a billet steel--I believe Hays brand
(came from sst as part of their kit)
It's externally balanced
post #9 of 13 (permalink) Old Aug 25th, 19, 5:11 PM
J
Looking good! Did you get a dial plate or will you be taking the Magnum front plate off to dial in the bellhousing?
post #10 of 13 (permalink) Old Aug 25th, 19, 6:57 PM Thread Starter
Dial plate
No way I'm taking thag front off and voiding my warranty!(I couldn't imagine the swap before they made that plate)
post #11 of 13 (permalink) Old Aug 31st, 19, 11:37 PM Thread Starter
More process. Hope to get the trans in so I can measure for drive shaft and get mine shortened. Also need to measure for throw out bearing gap
Bell housing was in alignment!
ID:	602074   Click image for larger version
ID:	602076   Click image for larger version
ID:	602078   Click image for larger version
-SS454- likes this.
post #12 of 13 (permalink) Old Aug 31st, 19, 11:58 PM
Mc Cleod scattershield is foolpoof no messing around with dowels.
Recheck your balance. CF DF had good luck.
cuisinartvette is offline
post #13 of 13 (permalink) Old Sep 1st, 19, 12:53 AM Thread Starter
This one is a QuickTime shield
What do you mean check balance - - if the clutch?
