Posi units. - Chevelle Tech
 2Likes
  • 2 Post By big gear head
post #1 of 15 (permalink) Old Aug 24th, 19, 6:36 AM Thread Starter
Durand
Posi units.
Who makes the strongest/most durable posi carriers?
LaVelle is offline
post #2 of 15 (permalink) Old Aug 24th, 19, 11:41 AM
Freddie
Re: Posi units.
For which rear end? Assuming you are talking about the 12 bolt, the Detroit Locker is one of the strongest. If you want something smoother then the Eaton Truetrac and the Eaton Posi are good. Tom's Differentials was making special heat treated gears for the Eaton Posi, but I don't thin they are available anymore. I don't care for the carbon fiber clutches that are being used in the new Eaton Posi, but those can be changed. I think the Wavelock is available for the 12 bolt, but I'm not sure. It's probably the strongest of all, but very expensive.
fr8dog and davewho1 like this.
big gear head is offline
post #3 of 15 (permalink) Old Aug 24th, 19, 4:35 PM Thread Starter
Durand
Re: Posi units.
Actually, I was thinking 9 inch.
I have a nice 12 bolt now, but I'll be increasing the HP significantly here soon and don't want to destroy it.
So I'm looking into the 9 inch housings and posi units.
Thinking Moser Fab 9 housing and axles w/35 splines, but haven't decided on posi unit yet.
Most everyone agrees Eaton makes a good unit, but I'm curious about first hand experience with the Wavelock's as I am kind of leaning that direction.
LaVelle is offline
post #4 of 15 (permalink) Old Aug 24th, 19, 4:42 PM
Re: Posi units.
Shouldn't that be Wavetrac?
Running one behind a MJ 496, quite as a mouse and smooth as silk.
It is in a Moser inch and yes they ain't cheap.
edspdog is offline
post #5 of 15 (permalink) Old Aug 24th, 19, 5:18 PM
Jason
Wavetrac and it has a lifetime warranty.
Mines been great and it’s smooth with no noise.
Jasons 69 Chevelle is offline
post #6 of 15 (permalink) Old Aug 24th, 19, 6:47 PM Thread Starter
Durand
Re: Posi units.
Yes it is Wavetrac.
My engine will be coming from a little farther west than MJ's.
Ya they're proud of them.
LaVelle is offline
post #7 of 15 (permalink) Old Aug 24th, 19, 7:06 PM
Re: Posi units.
When I replace my spool it will be with a Wavetrac. I don't know how much power you'll be making but I'm not remotely worried about my 12 bolt with 35 spline axles.
70 Camino...Roller
Tommy the Cat is offline
post #8 of 15 (permalink) Old Aug 24th, 19, 10:41 PM
Freddie
Re: Posi units.
You will be limited on which limited slip differential you can use with 35 spline axles. The Traction Lock and Auburn are not available in 35 spline, and those are both junk anyway, so no big deal. The Truetrac may be available in 35 spline, but I'm not sure. The Detroit Locker is available in 35 spline and the Wavetrac (sorry I got the name wrong before). Both are good, but the Wavetrac is smoother and more expensive.
post #9 of 15 (permalink) Old Aug 24th, 19, 11:32 PM
Re: Posi units.
The Wavetrac is only available in 35 spline and sold exclusively through Moser. I think you're right about the Truetrac being available in 35 but I haven't heard a lot of good things about them in high power cars. I'll probably try one in my C20 because there isn't really any other option. Besides, the 14 bolt is so huge it would be easy to make a strong unit. I have Detroits in a couple of off road rigs and I would never use one in a street machine. Eventually I'll pull the Detroit out of the rear of my FJ40 in favor of an ARB air locker. I'll leave the Detroit in the front. Detroits are bullet proof but really miserable on the street. I much prefer the spool to the Detroit.
It's really what you're willing to put up with
70 Camino...Roller
post #10 of 15 (permalink) Old Aug 25th, 19, 12:07 AM
Freddie
Re: Posi units.
I've been running a Detroit Locker in my Camaro on the street for about 20 years with no issues. It's a 4 speed car and it really doesn't make much noise or cause any problems. I've run Power Trax Lock Right kits in 2 of my trucks for about 24 years with no problems, and just a little noise. They were both 5 speeds. They work better on the street than a spool. I've driven my Camaro on the street with a spool for just a few miles and hated it.
post #11 of 15 (permalink) Old Aug 25th, 19, 2:31 PM
Beth
Re: Posi units.
The Strange S60 with the S-trac helical posi is just as strong as a wavetrac from what I've read. Don't have any personal experience with either (yet).
Here's a nice thread about the S-trac and wavetrac :
https://ls1tech.com/forums/gears-axl...ge-s-trac.html
Just bought an S60 with the S-trac and as far as looks go, looks a lot better than a 9" to me LOL
nashville beth is offline
post #12 of 15 (permalink) Old Aug 25th, 19, 3:12 PM
Re: Posi units.
The S60 is the answer if you can live with a 3.50+ gear ratio.
70 Camino...Roller
post #13 of 15 (permalink) Old Aug 25th, 19, 5:06 PM
Re: Posi units.
Originally Posted by LaVelle View Post
...but I'll be increasing the HP significantly here soon and don't want to destroy it.
Skip right to a Strange Dana 60. You'll never worry about your rear.
...Thinking Moser....
yeah...no to the Moser-even their D60.
Strange makes a better rear.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #14 of 15 (permalink) Old Aug 25th, 19, 5:15 PM
Freddie
Re: Posi units.
I like the S60, except for the housing ends. Strange housing ends don't have a place for a factory type axle seal. Moser does. I was going to get a S60 for my '67 Chevelle and order it without ends. Then I was going to put Moser ends on it. Haven't done it yet. I don't think my Chevelle is going to get built.
post #15 of 15 (permalink) Old Aug 25th, 19, 5:52 PM
Jason
You can buy a wavetrac for a 9 inch with 35 splines $795 from Quick performance. No need to go through Moser. Lifetime Warranty is transferable.
The wavetrac pressure angles are 30 degrees. Same as the Strange 35 splines.
I used a Wavetrac, Strange pro iron case, Strange 35 spline axles. Quick performance housing with 3.25 tubes. Only time you see issues with a Wavetrac is with Floater axles and wrong oil.
