9 inch ford question. posi, locker or spool? - Chevelle Tech
 6Likes
  • 2 Post By big gear head
  • 3 Post By Jim Mac
  • 1 Post By 25C 70
post #1 of 13 (permalink) Old Aug 23rd, 19, 7:28 PM Thread Starter
the new to me 70 el camino came with a 9 inch ford 4 link setup. got it in the air, gears are 3.90 or so, both tires turn the same way. has strange s/s axles and the front pinion bearing plate looks like its aluminum so its been into. it's got the huge fill bung on top, drain on the bottom, the brace across the back. so it's not stock
Question is, do I have to pull the chunk to figure out what kind of posi, locker or spool? jim
70 chevelle, SS clone 454 4 speed 3.31 12 bolt posi
71 camaro. (owned since 1978!) 454-th400 3.07 12 bolt
66 chevelle 350 4 speed 3.55 12 bolt and a newly added 142 wieand blower
Jim Mac is offline
post #2 of 13 (permalink) Old Aug 23rd, 19, 8:39 PM
Re: 9 inch ford question. posi, locker or spool?
Jack it up so that only one of the rear tires is off the ground. Then try to spin the one that is in the air. If it won't spin it probably has a spool.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is offline
post #3 of 13 (permalink) Old Aug 23rd, 19, 8:43 PM
Any chance you have access to a flexible borescope?
You could take the top fill bung off and stick the borescope down and in to possibly see what's in there.
Heck, you might even be able to snap a few pics down that hole with a light/flash and see the middle of the pumpkin to tell what is in there.
lucifershammer is online now
post #4 of 13 (permalink) Old Aug 23rd, 19, 9:10 PM
Jason
There should be a serial number on the front of the center section. Give that to strange if they built it. That would be the easiest way. Strange has a wavetrac style diff also s trac or something like that.
Jasons 69 Chevelle is offline
post #5 of 13 (permalink) Old Aug 23rd, 19, 9:17 PM
Freddie
Could be just about anything. The only way to know is to look inside somehow. Both wheels will turn together with a spool, locker or a limited slip differential (Ford is not called Posi. That's Chevy only). I've even seen standard differentials spin both wheels together when someone has been doing too many one wheel burnouts and got it so hot that it welded it's self together. You need to see inside. Maybe your phone has a light next to the camera lens so that you can take a picture through the hole with the light turned on.
Steve R and fr8dog like this.
big gear head is online now
post #6 of 13 (permalink) Old Aug 23rd, 19, 9:40 PM Thread Starter
I pulled the rear and it has a big filler cap on the housing. Big enough to peak into the pumpkin. Its a spool. Jim
Jim Mac is offline
post #7 of 13 (permalink) Old Aug 23rd, 19, 9:42 PM
Freddie
Not very street friendly. The Truetrac is very popular with the 9 inch Ford owners. I do not recommend the Auburn or any version of the Traction Lock.
post #8 of 13 (permalink) Old Aug 23rd, 19, 11:53 PM Thread Starter
The truck has a 4 link set up in the rear with provision forba panhard bar. Front is lowered with a big1.25 sway bars and coil over spring/shocks.
9in is out and getting traded or sold. Going to put a 12 bolt back into it. Jim
Jim Mac is offline
post #9 of 13 (permalink) Old Aug 24th, 19, 12:45 AM
Someone will buy it, if its stock width it will also fit 70-81 Camaros and Firebirds plus 75-79 Novas.
Steve R
Steve R is online now
post #10 of 13 (permalink) Old Aug 24th, 19, 12:56 AM Thread Starter
60.5 inches wide from axle flange to flange. has the brackets for the 4 link and panhard bar on it, plus the rear brace. jim
Jim Mac is offline
post #11 of 13 (permalink) Old Aug 24th, 19, 6:53 AM
If it is a 31 spline you could replace it with one from a ford truck. A Ford posi has the letter L in the ratio listed on the ID tag. This tag is attached to a center section stud. EX. 3.50= non posi, 3L50= posi.
fr8dog likes this.
25C 70 is offline
post #12 of 13 (permalink) Old Aug 24th, 19, 10:42 AM Thread Starter
just 4 bolts on the end and the axle slides out? jim
Jim Mac is offline
post #13 of 13 (permalink) Old Aug 24th, 19, 11:50 AM
Freddie
Yes, the axles are held in by the 4 bolts that also hold the brake backing plate on. Sometimes the axles are stuck and need a little coaxing to get them out.
