trans leak - Chevelle Tech
post #1 of 7 (permalink) Old Aug 22nd, 19, 3:11 PM Thread Starter
p40
butch
trans leak
hey all . i have an m21 muncie i put in my chevelle not to long ago , when i was changing out the clutch i noticed a little gear oil inside the bell , checked trans while it was out nothing coming out from around the bearing retainer or counter shaft but did look like a little coming from the weep hole on the retainer any ideas why it would leak there, thanks for all the help
p40 is offline
post #2 of 7 (permalink) Old Aug 22nd, 19, 3:56 PM
Re: trans leak
Is it over filled?
oldcutlass is offline
post #3 of 7 (permalink) Old Aug 22nd, 19, 4:33 PM Thread Starter
p40
butch
Re: trans leak
Originally Posted by oldcutlass View Post
Is it over filled?
no, filled to the bottom of the fill plug.
p40 is offline
post #4 of 7 (permalink) Old Aug 23rd, 19, 2:58 PM
Harold
Re: trans leak
Muncie has no front seal.Overfill or parked on a slope will show a leak
Who knows why no provisions for a seal ...transmissions from the 40s had a seal, even it was made out of leather..
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #5 of 7 (permalink) Old Aug 23rd, 19, 5:09 PM Thread Starter
p40
butch
Re: trans leak
not over filled, parked level in garage , there has to be a reason for it leaking other than what u suggested.
p40 is offline
post #6 of 7 (permalink) Old Aug 23rd, 19, 6:40 PM
Rame
Re: trans leak
Thats where the vent is, as to why oil is coming out it could be a number of things such as the ones suggested or improper building, case stretch, oil quality, etc. Whats the age of the oil and type (some oil is starting to suck these days)? Condition of the trans? How hard do you run it? All in all it's probably not worth it to worry about it unless you are drag racing, just keep an eye on it.
sampoerna415 is offline
post #7 of 7 (permalink) Old Aug 23rd, 19, 8:45 PM Thread Starter
p40
butch
Re: trans leak
i found some lube at rural king its a g5 type for gear boxs, i bought trans 2 years ago used , it shifts flawless, and sync are in great shape, i dont run run the car hard its just a cruiser anymore quit racing in 2013 thanks for the info
p40 is offline
