Auto shifter recommendations - Chevelle Tech
 19Likes
post #1 of 23 (permalink) Old Aug 16th, 19, 8:17 PM Thread Starter
Alex
Need to get a shifter for my RMVB TH400. I think I would rather have a ratchet style . Looking for any good or bad feedback on what yall have used and liked/disliked.
1969 Chevelle SS --- 468 FTI Level 4 TH400 AFR 290cc's
1997 S10 SS ---LQ9/4l65e
Chevymec is offline
post #2 of 23 (permalink) Old Aug 17th, 19, 7:39 AM
I have never had a ratchet shifter, but I have considered buying a B&M Star Shifter. I used to have a Hurst quarter stick in my '68 until I took it out and put it back on the column. It was a manual valve body TH400. Here is a photo of the shifter and console I fabricated for it.
Chevymec likes this.
68elky396 is offline
post #3 of 23 (permalink) Old Aug 17th, 19, 8:50 AM
re: Auto shifter recommendations
Check out the B&M Stealth Ratchet shifter, works great for me.
The problem with designing something completely foolproof, is you underestimate the ingenuity of complete fools. - Douglas Adams
db11020 is online now
post #4 of 23 (permalink) Old Aug 17th, 19, 8:55 AM
I've got a B&M Quicksilver and it works quite nicely.
1972 Chevelle, 454, 2004r, 4.10
lucifershammer is offline
post #5 of 23 (permalink) Old Aug 17th, 19, 9:48 AM Thread Starter
Alex
That is one I have already considered. Really like the looks of it.
Chevymec is offline
post #6 of 23 (permalink) Old Aug 17th, 19, 11:10 AM
Bruce
I used to have a Hurst Dual Gate 2, until it broke.
I considered a B&M QuickSilver (that mounts directly in the stock '69 console), but I passed on it because it is a true ratchet shifter where the handle dosen't really move, it just kind of rocks back and forth.
I settled on a GM factory slap shifter (push right and forward to shift, then release and repeat) from a '73 Chevelle. This style shifter was introduced in the '68 GTOs and was also used in several other A Bodies and F Bodies. The downside was I had to install a GTO console (it looks great, but was costly).
If you like the GM Staple Shifter, there's a member here selling an upgrade that allows ths shifter to be a push from 1st to 2nd, followed by a push from 2nd to 3rd. If I hadn't invested in the shifter/console I'd have gone that route. Check it out.
Our You Tube Vids:
NickeyChevelle is offline
post #7 of 23 (permalink) Old Aug 17th, 19, 11:44 AM Thread Starter
Alex
My car is a factory 4 speed with a bench seat. No console in my car.
Sent from my SM-G930V using Tapatalk
Chevymec is offline
post #8 of 23 (permalink) Old Aug 17th, 19, 12:29 PM
Bruce
It was a four speed manual and is now an auto? If that's so, then a B&M Quick Silver and their small consolette.
Our You Tube Vids:
post #9 of 23 (permalink) Old Aug 17th, 19, 12:45 PM
Greg.
I put this one in my car this Spring with a newly Rebuilt TH400 Reverse Manual VB and much higher Stall
https://www.jegs.com/i/B-M/130/80842/10002/-1
Love how smooth everything works
Just having to get use to 50+ years of Shifting Forward to now doing it the opposite way
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is online now
post #10 of 23 (permalink) Old Aug 17th, 19, 2:14 PM
Hurst Auto stick I would look good... Crash
crashent is offline
post #11 of 23 (permalink) Old Aug 17th, 19, 4:57 PM
Me too!
lucifershammer likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #12 of 23 (permalink) Old Aug 17th, 19, 4:59 PM
Bruce, I'd like to know more about this. Do you have any pics?
How may I help you?
1999 Trans Am-500hp
post #13 of 23 (permalink) Old Aug 17th, 19, 8:16 PM
Bruce
The shifter is called a slap or bump shifter. It was originally introduced in 1968 for the GTO and performance Firebird. There are two versions of the Pontiac shifter: Slap/bump and non. You'll want the slap/bump shifter where the shift stick move to the right (non-slap/bump shifter don't move laterally). In 1968 the shifter had two legs and used the console as a third mounting point. In 1969 or 1970 Pontiac added two more legs for a much stronger mounting -- I'd defiantly get the four leg version.
Chevrolet started using this shifter in the 1970 and up Camaros and in 1973 with the Chevelles. I have the 1973 shift button from an SS Chevelle and it says "SS" on it.
The one I got was disassembled, media blasted, and the stick was rechromed. Here's one on eBay: https://www.ebay.com/itm/70-81-REBUI...oAAOSw90NcShJb
The trouble is you'll need a GTO console (or a 1973 Chevelle console UGLY) to use this shifter.
ID:	600878   Click image for larger version
ID:	600880   Click image for larger version
ID:	600882   Click image for larger version
paul bell and Chevymec like this.
Our You Tube Vids:
post #14 of 23 (permalink) Old Aug 18th, 19, 7:57 AM
Hurst Autostick I. Has gates on the performance side, is directly bolted to the transmission and has direct linkage like the four speed.. Looks the best to me. I also had a Trans works detent plate to the stock shifter, it worked real nice for a cable shifter..
hydro462 is offline
post #15 of 23 (permalink) Old Aug 18th, 19, 8:00 AM
https://www.chevelles.com/forums/33-...-thread-2.html
Hurst Autostick I shifter..
hydro462 is offline
