how difficult to convert from PG to turbo 350 in a '64 SS hardtop? - Chevelle Tech
 3Likes
  • 1 Post By senna
  • 1 Post By oldcutlass
  • 1 Post By 64elkynss
post #1 of 11 (permalink) Old Aug 11th, 19, 6:02 PM Thread Starter
anybody in the group done this before? Would like to keep using the stock shifter/console. Still running a 327. Clearance issues for shifter? Which neutral safety switch do I use or do I have to modify the original switch? I have the kit which changes to a cable, has new shifter detent, etc. Is this even a possibility to do without difficult mods? Thanks for any help.
Yeah, we're runnin' a little bit hot tonight,
I can barely see the road from the heat comin' off,
You know what I'm sayin',
Ahh, you reach down, put it between my legs 'n
ease the seat back,
She's runnin', I'm flyin',
Right behind in the rear view mirror now,
Got the fearin', power steerin',
Pistons poppin', ain't no stoppin' now,
PANAMA!
64elkynss is offline
post #2 of 11 (permalink) Old Aug 11th, 19, 8:31 PM
Re: how difficult to convert from PG to turbo 350 in a '64 SS hardtop?
Its a very easy swap. Shifter linkage hooks the same, trans xmember stays in the same spot, and all you need to ad is a detent cable for passing gear.
oldcutlass is offline
post #3 of 11 (permalink) Old Aug 12th, 19, 2:29 PM
Not hard at all both same size and uses same drive shaft, as mentioned the detent cable setup
Bradco is offline
post #4 of 11 (permalink) Old Aug 12th, 19, 2:38 PM
"Wild Bill"
Super easy swap...done it a few times.
Same length, same driveshaft yoke, same trans cooler lines, same speedo cable, same flexplate and starter.
Just have to run the kickdown cable to the carb.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #5 of 11 (permalink) Old Aug 12th, 19, 2:48 PM
Marcus
As others said pretty easy swap.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #6 of 11 (permalink) Old Aug 12th, 19, 8:41 PM Thread Starter
thanks for all the input. So I can use the original neutral safety switch for the powerglide or do I have to change it to something else? I had a feeling it was an easy swap, but that switch is the one I was unsure about.
ease the seat back,
PANAMA!
post #7 of 11 (permalink) Old Aug 12th, 19, 9:43 PM
Troy
Take a look at this
https://shiftworks.com/collections/c...conversion-kit
64elkynss likes this.
66 CHEVELLE
senna is offline
post #8 of 11 (permalink) Old Aug 12th, 19, 10:09 PM
You can still use the original neutral safety, park reverse and neutral basically stay within the same positions, the only issue is that the 1st through D are squeezed together into the old 2 position area and don't line up 100% correctly. The above post can correct this, I just count the detents as to what gear I'm in with a 2 speed to T400 conversions.
post #9 of 11 (permalink) Old Aug 13th, 19, 10:18 PM Thread Starter
Thanks, Troy, for the link to Shiftworks. I totally forgot all about them! Time to place an order
senna likes this.
ease the seat back,
PANAMA!
post #10 of 11 (permalink) Old Aug 14th, 19, 2:36 PM
Harold
when did powerglide change from 16 spline output to 27 spline ?
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #11 of 11 (permalink) Old Aug 14th, 19, 6:44 PM
von
Lifetime Founding Member
Von
When I switched from PG to TH350 in my '69 I had to do some cutting and welding on the shift linkage between the frame bracket and trans. Also had to do some bending of the cooler lines. Added a TH350 kickdown linkage too.
[img]
von is offline
