Driveshaft rubbing - Chevelle Tech
 19Likes
post #1 of 29 (permalink) Old Jul 30th, 19, 12:25 AM Thread Starter
Need some help here with a driveshaft issue. I just lowered the rear end with BMR 2” lowering springs. Now, when I am driving and hit dips in the road the driveshaft is rubbing on the floor pan under the back seat area. It’s rubbing in two spots ( see attached pictures). I am going to end up taking it to the local shop to have it fixed.
What I am looking for is some input as to what would cause the driveshaft clearance to be so small? Car is a 65 and has a Borg warner T-10 tranny and a 396 in it, 12 bolt rear end. It’s is lowered 2” in the front, 2 in the rear.
Just want to have an idea what possible problems/solutions are when I take it in.
ID:	599286   Click image for larger version
SCV1965SS is offline
post #2 of 29 (permalink) Old Jul 30th, 19, 8:57 AM
Re: Driveshaft rubbing
It's what can happen when you lower a car.
Old school method: a great big hammer.
Seriously, it's the easiest way to solve the problem. A little "tweaking" in the rub areas. Unless you want to remove the whole interior and install a new larger driveshaft tunnel.
HKalin and BTK like this.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #3 of 29 (permalink) Old Jul 30th, 19, 12:36 PM
Dennis
My 66 has 2 dropped spindles and 2 dropped springs in the front and 2 dropped springs in the rear and My driveshaft does not rub. Im going to switch to 3 dropped springs in the rear but will enlarge the driveshaft tunnel first.
I already had to enlarge the transmission tunnel. I should have done them both at once
67_LS1 is offline
post #4 of 29 (permalink) Old Jul 30th, 19, 1:23 PM
How's your pinion angle compared to the transmission yoke angle now? If the pinion angle is "pointing up", you may be able to get the clearance you need by installing adjustable upper control arms and bringing it down some. This assumes this doesn't throw your front/rear angles out of tolerance.
jim
Kirk's67SS likes this.
Jim's69Ragtop is offline
post #5 of 29 (permalink) Old Jul 30th, 19, 1:31 PM Thread Starter
So if I did want to modify the tunnel, backseat comes out, carpet gets pulled back, cut, and weld in a new tunnel with more clearance ? Anyone have an idea what this should reasonably cost ?
post #6 of 29 (permalink) Old Jul 30th, 19, 2:12 PM
Have you already changed out the body bushings? Worn body bushings can do this. Easier to change out than building a new tunnel.
JWagner, -SS454-, blm and 1 others like this.
post #7 of 29 (permalink) Old Jul 30th, 19, 2:15 PM
Greg.
Is your Driveshaft new ?
is it too long ??
and therefore jaming/bottoming out into the Trans making the Shaft go up into the Tunnel when there are dips in the road
Cutting up the Tunnel is a last resort, instead raise up the Rear
See # 4 Post as the best solultion & likely the Reason for the Driveshaft Rubbing on the Tunnel
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #8 of 29 (permalink) Old Jul 30th, 19, 2:23 PM
& Administrator
What Gene said.
Mike is offline
post #9 of 29 (permalink) Old Jul 30th, 19, 2:25 PM
Another option is a Ford 9 inch... the lower pinion position will allow more room and offer better driveline angles compared to the 12 bolt. This is not a budget solution, but it is another solution.
dell72 is offline
post #10 of 29 (permalink) Old Jul 30th, 19, 2:25 PM
Look into what Gene said about body bushings and also check to see if the rear transmission mount is the correct one.
JWagner is offline
post #11 of 29 (permalink) Old Jul 31st, 19, 1:42 AM
Dennis
Agree with all. Tunnel cutting should be a last resort. Its a lot of work = expensive.
The nine inch with its lower pinion is a solution I hadnt thought about. In my case Im running a V6 so I dont need it for strength but something to consider.
Body mounts would be the easiest/least expensive. Adjustable uppers could help and are fairly simple to install.
Do you know what your current rearend and transmission output shaft angles are?
67_LS1 is offline
post #12 of 29 (permalink) Old Jul 31st, 19, 1:47 AM Thread Starter
I don’t know what the angles are , but when I take it to my shop next week, I’ll have them take a look and see if it’s set up properly
post #13 of 29 (permalink) Old Jul 31st, 19, 1:47 AM
Levon
If the car has a 4 speed, it's possible you have a transmission mount (TH400) that is too tall. It will cause a rub at the front of the driveshaft.
JWagner likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #14 of 29 (permalink) Old Jul 31st, 19, 11:42 PM
Could add in a rear coil, thicker rubber spacer and lift the car 1/2" or so.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #15 of 29 (permalink) Old Aug 1st, 19, 6:45 PM
Also check all rear upper and lower control arm bushings. If these are old and worn there will be slop in the suspension from these parts as well as body bushings...
69' SS396 Chevelle L78 396/375hp M-21 Close Ratio Cortez Silver
10 year Resto
It's brand new again!
02' Harley FatBoy, Diamond Ice Pearl and lots of chrome!
ACES# 3466
fastss396man is offline
