pieces of metal from axle - Chevelle Tech
post #1 of 14 (permalink) Old Jul 24th, 19, 7:53 AM Thread Starter
Jay
Had some squealing in the left rear wheel. Took off the drum and pieces of metal fell out (see pic). Took some video of the squealing, which continues, not surprisingly. https://youtu.be/M0rqR_ow0Jw Assuming this is a broken bearing?
It’s a Pontiac rear, 9779822. Thanks!
jat70 is offline
post #2 of 14 (permalink) Old Jul 24th, 19, 9:24 AM
Freddie
Re: pieces of metal from axle
Yeah, that looks like parts of the bearing.
big gear head is offline
post #3 of 14 (permalink) Old Jul 24th, 19, 11:09 AM
Agreed.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #4 of 14 (permalink) Old Jul 24th, 19, 12:32 PM Thread Starter
Jay
Thanks, guys. I'll be researching how to change the bearing. If the right side is fine, any reason I should change that? The car has 2.56 gears. Is it a significant amount of additional work to change them since I believe I need to take the cover off the differential?
jat70 is offline
post #5 of 14 (permalink) Old Jul 24th, 19, 9:48 PM
Freddie
If it's a Pontiac rear end then you don't need to remove the cover to change the axle bearing. The axle is held in with 4 bolts that also hold the brake backing plate on. Remove the nuts and pull the axle out. It may be stuck, so sometimes a slide hammer is needed.
Yes, changing the gears is a significant amount of additional work.
post #6 of 14 (permalink) Old Jul 25th, 19, 1:17 PM Thread Starter
Jay
Good deal, thanks. I think I'd prefer to not have to remove the cover. Not crazy about it if I have to dismantle the brakes, but that's at least a sit down job instead of a lay down job. That's good info, though. I am hoping to rent the slide hammer tool from a local parts store.
Last question. How do I determine what size it is? 8.2, 8.5. I know little about axles and rear ends right now. I'll be learning as I go through this repair.
jat70 is offline
post #7 of 14 (permalink) Old Jul 25th, 19, 2:27 PM
Jon N.
8.5 has square lugs that stick down like corners on the center housing casting. 8.2 doesn't.
Jon N.
dyno jonn is offline
post #8 of 14 (permalink) Old Jul 25th, 19, 3:37 PM
Freddie
Pontiac used their own version of the BOP 8.2 rear end in the A body from '64 to '72. If this is an original rear end from those years then you have the 8.2 Pontiac rear end.
post #9 of 14 (permalink) Old Jul 25th, 19, 4:42 PM Thread Starter
Jay
Googling for pics. Having a hard time visualizing this, but I suspect it's the 8.2...
...because the casting number 9779822 comes up as the years above. I attached a pic, if that identifies it. I am skeptical i'll be able to determine what parts to buy even when I disassemble it. Hoping it only needs a bearing
jat70 is offline
post #10 of 14 (permalink) Old Jul 25th, 19, 4:52 PM Thread Starter
Jay
looks like an 8.2
jat70 is offline
post #11 of 14 (permalink) Old Jul 25th, 19, 5:07 PM
Freddie
That is the BOP 8.2.
post #12 of 14 (permalink) Old Jul 25th, 19, 5:20 PM
Randy
Jay, with bearing pieces coming out of it, don't be surprised if the axle surface is trashed. If there's significant wear marks on it, you'll need a new axle.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #13 of 14 (permalink) Old Jul 25th, 19, 10:03 PM Thread Starter
Jay
This was way better than having to take the cover off. Took 5 minutes to get it out. I don't feel any scoring, despite the color difference. Thank you for the confirmation on it being an 8.2.
ID:	599070   Click image for larger version
ID:	599072   Click image for larger version
jat70 is offline
post #14 of 14 (permalink) Old Jul 26th, 19, 12:25 AM
WELL, in the mid-70s (73-76) there were also some GM corporate 12bolt rears that were TOTALLY different (and larger) from the 65-72 Chevy 12bolt rears. They were often installed in wagons (such as 76 Cutlass wagons) and some El Caminos. They also had the 10bolt covers with 2 big notches (which is misleading to most folks). Unfortunately, these 12bolt rears only came with "hiway" gears (3.08, 2.73, 2.56, etc). And 11in drums. They had larger, 32spline axles. In 77, the same 12bolt GM corporate rear was used, BUUUUUUUUUUT, the axles went to a 28spline-----------the rest of the axle was the same diameter as the 73-76 32spline axles. Maybe Freddie (Big Gear Head) can expand on this a little more.
Posi in these rears was RARE, RARE, RARE!
Here is a typical Chevy 12bolt NON-posi unit (left) and the later GM corporate 12bolt posi. Both are Eaton 2-series. As can be seen, the GM corporate unit is larger than the 65-72 Chevy 12bolt. It also used larger 7/16 LEFT hand thread bolts.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
