Differential and Transmission upgrade - Page 2 - Chevelle Tech
 35Likes
post #16 of 85 (permalink) Old Jul 25th, 19, 12:25 AM
Freddie
Re: Differential and Transmission upgrade
I wasn't clear on that. You listed 3.42 and 3.54 as gear ratio options for your rear end. Those gear ratios are not available for the 8.2 10 bolt, which is what I assumed you had because that is what would have been in that car. The correct gear ratios in that range for that rear end would be 3.36 and 3.55.
big gear head is offline
post #17 of 85 (permalink) Old Jul 25th, 19, 12:50 AM
Originally Posted by jelco View Post
How does ‘big gear head’ know my GM1 rear end originally came with a 3.36 or 3.55 gear ratio?
Searching online showed “GM1” stamper rear end is 2.56.
What is a good 10 bolt 8.2” kit to purchase for a daily driver?
I’ve watched several YouTube videos but if anyone knows of a good one that is more specific to my car, please don’t hesitate.
Freddie, aka Big Gear Head, is our resident expert on rear ends. He was simply letting you know that 3.36 & 3.55 gears are your choices when it comes to 8.2 10 bolts if you wanted to lose your 2.56 gears
3.23 & 3.42 are ratios for GM 8.5 10 bolts. Neither will work for your application.
big gear head likes this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #18 of 85 (permalink) Old Jul 25th, 19, 1:21 AM Thread Starter
Ok thanks for the clarification. So get 3.36 or 3.55 3 series and replace the axles?
Several sites indicate a "GM1" has a 2.59 gear ratio (I mistyped 2.56 earlier), I haven't determined by counting the ring and pinion gears if it has been left that way over the past 55 years.
Do I have y'all's blessing to go ahead with 3.36 or 3.55 gear ratio if I leave the engine and tranny stock for a few months then switch to 200-4R or 700R4 and a salvaged LS1 down the road?
jelco is offline
post #19 of 85 (permalink) Old Jul 25th, 19, 8:56 AM
In the 10 bolt, yes.
post #20 of 85 (permalink) Old Jul 25th, 19, 9:10 AM
If you are going to an overdrive transmission, do yourself a favor and go with the 3.55’s. With a low horse engine and low cruise rpm the car could be a little balky with the other gear.
71350SS, lucifershammer and Dansk like this.
Originally Posted by Jordan Peterson
The motivation that drives the commission of the worst human atrocities is an inevitable social consequence of the refusal of the self conscience individual to make the sacrifices appropriate to establishing a harmonious life and their consequent degeneration into a kind of murderous and resentment filled rage propagating endlessly through its variations in society until everything comes to an end.
Alan F is offline
post #21 of 85 (permalink) Old Jul 25th, 19, 9:50 AM
Freddie
I agree, the 3.55 would probably be best with overdrive. If you think that you may not go through with the overdrive installation then use the 3.36.
71350SS and 427L88 like this.
post #22 of 85 (permalink) Old Jul 25th, 19, 12:10 PM Thread Starter
I called Quick Performance and they said 3.55 or 3.73 would be good with overdrive, 150rpm difference with the 3.73.
Would I get better gas mileage around town with the 3.55?
jelco is offline
post #23 of 85 (permalink) Old Jul 25th, 19, 4:32 PM
Freddie
Post pictures on here when you get started on this and we will help you read the pattern and help with direction on which way to go. Ask questions and you will get answers.
71350SS likes this.
post #24 of 85 (permalink) Old Jul 25th, 19, 7:04 PM
I have the 700 (did the swap about 20 years ago) and it holds up great. That said, buy a built 200 and you will be way happier. Nobody was building the 200's when I did the swap, so I had to shorten the driveshaft and modify the crossmember. You don't have to do nearly as much to use a 200, as it is the same length as your old transmission. Another advantage of the 200 is the gap between first and second gears is not huge. the 700 has a 3.06 1st gear and 1.62 2nd gear, and the 200 has a 2.74 1st and 1.57 2nd.
Shifting from 1st to 2nd at 5,000 rpm, the 700 will drop to about 2,600 rpm and the 200 to 2,900. I definitely feel the bog when the car shifts from 1st to 2nd.
I also have a (non-posi) 12 bolt with 2.73 gears and it is a highway monster. 2,000 rpm at about 80 mph. I think low to mid 3 series gears would be perfect.
Brad Waller
'66 Corvette | 352/??? | 4-speed | Wilwood Brakes | 245/50/16
'67 Chevelle | ex-SS396 | 355/700R4 | F-Body Brakes | 275/40/17
Brad Waller is offline
post #25 of 85 (permalink) Old Jul 25th, 19, 8:45 PM
Really the only major gear ratio difference is first gear. The rest are so close as to make little if any difference.
miketx is offline
post #26 of 85 (permalink) Old Jul 25th, 19, 9:48 PM
Greg.
Here is my 2 cents
if there is a Rearend in the car now drive it like it is for now as a DAILY driver
Then get all the right parts to swich over assembled
eg.
1. the right 12 Bolt Posi with the Gear Ratio to fit/match up to the new Engine / Trany / you are going use
2. get the 3/4 speed Trany you can afford with the lest amount of work needed to install it into your car
..... TH400 if you also want to do some fast fun time at the Track & Cruzin that is almost Bullet Proof with a 3.08 to 3.31 Gear Ratios in the 12 Bolt
..... 2004R for a Daily Driver & Cruzer with 3.55 or 3.73 Gear Ratios in the 12 Bolt
..... 4L80 for a Daily Driver & Cruzer with 3.55 or 3.73 Gear Ratios in the 12 Bolt
3. the Engine you want with it ready to go
..... LS SBC for good Gas Mileage and plenty of HP
4. a new Shifter to make sure the Trany will shift great
..... I just put a B&M Pro Ratchet in my 67 and I love how it shifts my Newly Rebuilt TH400 with a Reverse VB
5. a new correct lenght HD Driveshaft with 1350 Ujoints
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #27 of 85 (permalink) Old Jul 29th, 19, 8:19 PM Thread Starter
Originally Posted by Kirk's67SS View Post
Here is my 2 cents
eg.
Yeah, probably wise to wait to upgrade the rear end until I have the tranny and engine to upgrade with it. I'm going to try to find a decent salvage yard LS motor at some point then buy a rebuilt 200 or 7004R transmission. If I'm not racing I'm thinking I can stick with the 10 bolt 8.2" for a while before upgrading to the 12 bolt 8.875".
jelco is offline
post #28 of 85 (permalink) Old Jul 30th, 19, 2:05 PM
Greg.
If you gave me a 7004R FREE I would not put it in my car
would sell it to someone else who wants the problems it will have
jelco likes this.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #29 of 85 (permalink) Old Jul 30th, 19, 11:52 PM Thread Starter
Were you racing it?
I'm looking for a 200R4 since it will be easier to install but I've heard parts are easier to come by for a 7004R.
I'm not interested in a floor shifter, I'm just going to keep the original steering wheel shift.
jelco is offline
post #30 of 85 (permalink) Old Jul 31st, 19, 6:04 AM
Since you are in southern CA you could always go to bowtie overdrives for your 2004r. I think there are other shops down there as well. Be wise and have them build and install it. That way they own any issues. The 2004R can be finicky to get everything right. I think Bowtie has one of the best TV setups out there. Having said that, if I was planning an LS swap, I would also swap in a more modern transmission at the same time and forget about the 2004r or 700r4.
Kirk's67SS likes this.
Dansk is offline
