Gear and Pinion Change - Chevelle Tech
 8Likes
post #1 of 45 (permalink) Old Jul 21st, 19, 8:33 AM Thread Starter
wanted to know in case I decided to change the gear and pinion from the 4.33 to 3.73 as it is a 3 series carrier, can this be done while rear still in the car properly,
Bradco is offline
post #2 of 45 (permalink) Old Jul 21st, 19, 9:58 AM
Re: Gear and Pinion Change
The ring and pinion gears CAN be changed in the car. Although, I MUCH prefer to unbolt the entire axle housing assembly, roll it out from under the car and place the axle housing on jack stands and work on it that way, as below.
IF, just IF, for sure, your differential is a 3-series (posi or non-posi), then yes, you can install a 3 series ring gear on it and set it up.
Do you know if the rear is a 10 or 12bolt and if it is a non-posi or posi unit?
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #3 of 45 (permalink) Old Jul 21st, 19, 10:30 AM Thread Starter
12 Bolt Yes I am sure when I initially got it I had thread started and I verified the carrier #s and that it is using a spacer to use the 4 series Richmond gear it just I installed the rear about 3 weeks or so ago to see if the 4.33 would be good but was told it would be better with 3.73 with my 2004-r
Bradco is offline
post #4 of 45 (permalink) Old Jul 21st, 19, 11:11 AM
Freddie
Yes, I've done a few hundred of them under the car with the car on jack stands. It's not a lot of fun, especially when you are trying to crush the spacer to set the pinion bearing preload. I have a special set of jack stands that I can use on a bench when the rear end is out of the car. I can rotate the rear end in the position I want and lock it down. It's a lot easier that way.
big gear head is offline
post #5 of 45 (permalink) Old Jul 21st, 19, 11:23 AM Thread Starter
Hummmmm so either I take it back out and do it myself or take it out and take to a shop here to do it which I have no way to transport it.
Bradco is offline
post #6 of 45 (permalink) Old Jul 21st, 19, 11:38 AM
Rent a Home Depot truck. $20 for 90 minutes.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #7 of 45 (permalink) Old Aug 1st, 19, 8:45 AM Thread Starter
Best place to purchase ring and pinion and install kit, looking for Strange 3.73 also if I need Eaton type rebuild kit where to get those parts
Bradco is offline
post #8 of 45 (permalink) Old Aug 1st, 19, 7:24 PM
mark
I have a 4 series set of 3,73 used one year,,us gear I bought from strange
1965 malibu,03 silverado ss
M.J. 496
th350,4.11 3250lbs,+185 FOR ME
28x10.5 Hoosiers
9.85,135.50,1.35
mino65 is offline
post #9 of 45 (permalink) Old Aug 1st, 19, 9:00 PM
This might be helpful. Good read and then watch the video.
https://www.hagerty.com/articles-vid..._Friday_May_24
Team Chevelle Member (20 years and counting...
72soft-top is online now
post #10 of 45 (permalink) Old Aug 1st, 19, 9:59 PM
leo
www.ringpinion.com
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #11 of 45 (permalink) Old Aug 2nd, 19, 6:58 AM
My experience is that you will get as good a job and likely better if you do it yourself especially if Freddie is willing to guide as he did me. In the olden days transmission shops usually also did rear ends but the guys who really know what they are doing are drying up. I've seen horrible jobs done by one local shop here. I've done two myself with no issues. Both were done in the car and my advice to you is to take it out.
Dansk is offline
post #12 of 45 (permalink) Old Aug 2nd, 19, 9:25 AM
It makes it a lot easier to take the assembly out of the vehicle.
ZEN357 is offline
post #13 of 45 (permalink) Old Aug 2nd, 19, 11:45 AM Thread Starter
Update, took car to a machine shop older guy that I wa thinking on rebuilding the rear. We took it for a ride he told me that my u joint was bad /. I vibration bought one on way home on highway joint broke and I think drive shaft getting towed and will check further. Can I have this rebuilt or just buy new driveshaft? Always something but hey it’s all good
Bradco is offline
post #14 of 45 (permalink) Old Aug 2nd, 19, 1:21 PM Thread Starter
Driveshaft not broken just joint, end where joint goes in a little scrapped up. trying to remove drive shaft and seems to be stuck in transmission side worried about banging out going to see if I can change the joint under car without removing from transmission. also found I was able to take pinion nut off by hand, does that have to be torqued? and if so does anybody have that info
Bradco is offline
post #15 of 45 (permalink) Old Aug 2nd, 19, 6:04 PM
Greg.
John I would think any Nut/Bolt that has a lot of Movement on it would have a specific Torque required
If it is a steel Driveshaft I would have it Re-balanced with bigger U Joints
if it can be Re-balanced !
What size are your U Joints ? 1350s ??
Another thought
what kind of Posi Unit do you have ?
if you have the Auburn Posi Unit I would throw it out
if the Eaton Posi Unit then you could leave it in and just change the Gears
however I found that it is better to run a Helical Gear Dif/Posi Unit ( Worm Like) no Springs
https://www.strangeengineering.net/p...-s60-n-5.html/
this is in my S60 I bought from Strange and I love it
since you are in there all ready
something to ask Freddie about tho
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
