clutch adj - Chevelle Tech
 13Likes
post #1 of 30 (permalink) Old Jul 18th, 19, 5:53 PM Thread Starter
p40
butch
clutch adj
hey all when i put some free travel in my clutch pedal have a hard time getting in gear take out the free travel it goes in gear but its not smooth, need help thanks to all replies , 66 chevelle ss bb 427, zoom clutch, pp, like new flywheel all new z bar and linkage
p40 is offline
post #2 of 30 (permalink) Old Jul 18th, 19, 7:53 PM
Re: clutch adj
You should have 1" free travel at the pedal.
oldcutlass is online now
post #3 of 30 (permalink) Old Jul 18th, 19, 8:23 PM
Re: clutch adj
Did you know that:
Not all pressure plates have the same finger height;
Not all throw out bearings have the same installed height;
Not all release arms are the same length;
Not all pivot balls are the same height;
Not all flywheels have the same surface height?
Now stack the tolerances on any two of those items and you can get the problem you are experiencing. Been there, done that, got the merit badge.
Maybe you will find your answer in here.
https://www.chevelles.com/forums/33-...-part-2-a.html
Mencken: “The whole aim of practical politics is to keep the populace alarmed by menacing it with an endless series of hobgoblins, all of them imaginary.”
Alan F is offline
post #4 of 30 (permalink) Old Jul 18th, 19, 9:07 PM Thread Starter
p40
butch
Re: clutch adj
how far off the floor should the cluth start grabbing. mine is prob2 inches off floor.
p40 is offline
post #5 of 30 (permalink) Old Jul 18th, 19, 11:43 PM
leo
Re: clutch adj
That is just about perfect!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 30 (permalink) Old Jul 19th, 19, 10:43 AM Thread Starter
p40
butch
Re: clutch adj
does lengthening the clutch rod take out free play or shortening ?
p40 is offline
post #7 of 30 (permalink) Old Jul 19th, 19, 11:47 AM
Re: clutch adj
Lengthening the rod takes out the play.
p40 likes this.
SSJohn is offline
post #8 of 30 (permalink) Old Jul 19th, 19, 11:49 AM
Hank
Re: clutch adj
Yes, lengthening will takeout free travel at the top of the pedal which in turn will make the pedal catch higher off the floor. If you adjust it try one full turn of the rod and see how that is then go from there.
p40 likes this.
HKalin is online now
post #9 of 30 (permalink) Old Jul 19th, 19, 12:41 PM Thread Starter
p40
butch
Re: clutch adj
thanks john and hank , thats what i thought , but wasnt 100 percent sure. like i was saying when i go for the free play the trans just does want to go in gear, im wandering if i fab a longer clutch rod would that work . im 68 y/o and dont get up and down l hate to tear it apart again , any ideas thanks guys
p40 is offline
post #10 of 30 (permalink) Old Jul 19th, 19, 2:41 PM
Hank
Re: clutch adj
I'm your age too and know how the up and down isn't as easy as it used to be. The closer the pedal catches to the floor the more chance you would have a harder time shifting it and a better chance of the transmission grinding when you put it in reverse. When you drive it see if your really matting the pedal when you put it in. Every once in a while I would notice I wasn't pushing the clutch in all the way especially if I got a grind in reverse. If everything is set up right there should be no reason to go to a longer rod than the stock one that's in the car.
LeoP and p40 like this.
post #11 of 30 (permalink) Old Jul 19th, 19, 4:22 PM Thread Starter
p40
butch
Re: clutch adj
your spot on hank. the closer to the floor the clutch grabs the harder to go in gear i just dont know were to start every thing is brand new . i talked to a tech at zoom and he thinks i need an adj fork bal. im old school dont know nothing abought that stuff but im willing to listen if someone wants to explain how to adj it thanks
p40 is offline
post #12 of 30 (permalink) Old Jul 19th, 19, 4:27 PM
Al
Re: clutch adj
Check your clutch pedal stop. If it's original it will be about 3/16 to 1/4 inch thick. If it's thicker it may be a repop. You can trim it down to gain some free play.
The wrong clutch fork will cheat you out of fork movement. If you have a clutch fork with "wings" it's a Lakewood or truck fork. It's longer and results in less fork travel.
As Alan eluded, if your clutch fork angle is not correct you won't be able to achieve enough free play or clutch release. You'll smoke the throwout bearing if it's not releasing and you'll grind your gears and wear syncros if you don't get a full clutch release. No adding length of adjustment rod or bell crank modification can overcome an improperly set clutch fork angle.
Basically, you need to start at the top and adjust your clutch fork angle so it will work within the limits GM gave us to work within. This is done with an adjustable pivot ball or adjustable throwout bearing.
Check the item listed above and see if you can get it to work for you. You should be able to achieve some freeplay on the throwout bearing and still be able to get into reverse from neutral within about 9 seconds without grinding. If she grinds, you're not getting full clutch release.
Take a look at your clutch fork angle. The fork should we 5-7 degrees forward of parallel to the trans shaft with the fork held against the throwout bearing. It will be very close to the front of the bellhousing window. If it is clearly back of 90 degress, it will have to come apart and clutch fork angle corrected.
Fork on left is H.D. truck or Lakewood type. Fork on right is correct for 65- 72 Chevelle.
Name:	chevelle clutch fork vs truck fork.jpg
LeoP and HKalin like this.
DUTCH MAX HEADWORK is offline
post #13 of 30 (permalink) Old Jul 19th, 19, 4:37 PM
Al
Re: clutch adj
This is a primer of what you'll be going through if you need to adjust your clutchfork angle by using an adjustable pivot ball. It starts a bit into the video at 4:25. The beginning has tips that are worthy as well. After you get the pivot ball height set, apply red lock tight to all threads and reassemble. They like to come loose if you don't.
You might want to align your bell housing too. It's not fun, but might as well getter done if you have the beans now so it doesn't bite you in the butt later.
p40 likes this.
post #14 of 30 (permalink) Old Jul 19th, 19, 5:24 PM Thread Starter
p40
butch
Re: clutch adj
Part 16 How To Set The CFor The Big Block Chevy - YouTube
thanks al for the info and vidio awsome info on the vidio. i dont have the fork with wings so i should be good to go on that , who seels the adj pivit ball thanks
p40 is offline
post #15 of 30 (permalink) Old Jul 19th, 19, 5:25 PM Thread Starter
p40
butch
Re: clutch adj
i should say who sells the adj pivit ball
p40 is offline
