Possible Trans Issue - Chevelle Tech
post #1 of 6 (permalink) Old Jul 15th, 19, 9:42 PM Thread Starter
My car has recently developed a slight bucking when slowly pulling away from a stop. It only happens after the car has been driven for 25 to 30 minutes, when it's warming up I do not feel the bucking. The trans is a TCI TH400 with a 10" ATI converter. The rest of the combo is the typical 454 with a roller cam and a 12 bolt posi with 4.11's. I have the vacuum line for the trans and pcv valve plumbed into the same port, could this cause my issue? Fluid level looks good.
'70 Malibu, 454 w/Brodix Ovals, TH400 w/10" ATI, 12 bolt with 4:11's
2013 ZL1 Camaro, Ashen Gray Metallic, No Mods YET
rednecks70 is offline
post #2 of 6 (permalink) Old Jul 15th, 19, 10:02 PM
Rame
Re: Possible Trans Issue
Seems plausible , right when you take off I think it would loose vacuum in the line due to the pcv, plug the pcv line and see if it improves. I recall some others have problems with the brake booster plumbed in with the pcv so don't tie in there either.
sampoerna415 is online now
post #3 of 6 (permalink) Old Jul 15th, 19, 10:06 PM Thread Starter
Okay, I will give that a try. Fortunately I have hydro boost for the brakes so I don't have to worry about a vacuum source for the brake booster.
post #4 of 6 (permalink) Old Jul 15th, 19, 11:11 PM
Rame
Also they have vacuum restriction/check valves that you can play around with, GM had that stuff from the factory to fix weird stuff, might be worth looking into if nothing else works.
post #5 of 6 (permalink) Old Jul 16th, 19, 2:32 AM
mike
The modulator should only affect shift points. You could try starting in manual 1st, or in reverse to see if any change. Sounds more like an engine miss.
You can also try holding the brake while putting a light load on engine in drive to replicate the symptom.
slowmo55ss is online now
post #6 of 6 (permalink) Old Jul 16th, 19, 3:08 PM
Harold
try it in a turn , if its worse....maybe posi clutches sticking
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
