66' Drive shaft hits floor board - Chevelle Tech
 10Likes
  • 3 Post By 72soft-top
  • 1 Post By OO52
  • 1 Post By Billdini
  • 1 Post By SSJohn
  • 2 Post By oldcutlass
  • 1 Post By 68-13427
  • 1 Post By Kirk's67SS
post #1 of 11 (permalink) Old Jul 15th, 19, 1:43 AM Thread Starter
canosoup
Question 66' Drive shaft hits floor board
Our 66' Chevelle drive shaft hits the floor board when we slow while applying brake pressure.
Upon inspection the drive shaft sits ⅛" from the floor board and the trans mount needs to be replaced. Anyone know if a lower profile transmission mount would lower the drive shaft and where to purchase one? Thanks for the help.
ID:	598280   Click image for larger version
ID:	598282   Click image for larger version
Soup66ChevelleMalibu
Mike Campbell is offline
post #2 of 11 (permalink) Old Jul 15th, 19, 7:39 AM
Two thoughts come to mind:
1. The body bushings May need to be replaced?
2. Possible to get a thinner transmission bushing?
David Bates, LeoP and BTK like this.
72soft-top is offline
post #3 of 11 (permalink) Old Jul 15th, 19, 10:03 AM
Re: 66' Drive shaft hits floor board
Found this trans mount at Rock Auto. Not as tall as the usual Chevy mounts.
IIRC it was about 1/4" shorter.
Mike Campbell likes this.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #4 of 11 (permalink) Old Jul 15th, 19, 10:36 AM
That's a pretty sharp angle where the driveshaft is going into the tranny so I don't think it has anything to do with body bushings or body height. It might make it worse but not the cause. I would check the front motor mounts as well but something is not the correct part for sure and that could include the cross member. See if someone can take some measurements and pics.
Billdini is offline
post #5 of 11 (permalink) Old Jul 15th, 19, 3:29 PM
If you get a shorter trans mount be sure and check rad fan clearance with the shroud. 1/4 lower on the tail might raise the fan too much.
SSJohn is offline
post #6 of 11 (permalink) Old Jul 15th, 19, 4:32 PM
Your also missing a bolt. Have your checked your Ujoints?
boyd66k20 and Mike Campbell like this.
oldcutlass is online now
post #7 of 11 (permalink) Old Jul 15th, 19, 7:23 PM Thread Starter
canosoup
Checked the body bushings and they look good, looking/ordering at lower profile mounts now. Going to check the engine mounts and U joints tonight. Fan Awareness on my mind. Thanks All, ill post my progress.
post #8 of 11 (permalink) Old Jul 15th, 19, 7:28 PM Thread Starter
canosoup
There is one bolt where the hole threads are stripped so defiantly ordering a new mount.
post #9 of 11 (permalink) Old Jul 15th, 19, 10:35 PM
Terry
Threads are in the tail shaft housing, not the mount. Terry
68-13427 is offline
post #10 of 11 (permalink) Old Jul 16th, 19, 12:37 PM
Greg.
Mike when my DriveShaft/UJoint Nuckle was hitting the Floor of my car going over bumps/deps in the Hwy/Street
the old Speed Shop answer was to Bang/Dent the Floor Up
Went to another new Shop and they found that the Trans Tail Housing was Cracked on the Top where it could not be seen
and that the Driveshaft was a 1.5" to Long
and thus was dead hitting inside the Trans pushing the Slip Yolk/UJoint up into the Floor
after that stuff all got fixed and a Shorter Cross Member/Trans Mount replaced tha old higher one
they also had to adjusted the Pinion Angle, which was easy to do since I had UMI Perf great Adjustable Rear Upper Control Arms
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #11 of 11 (permalink) Old Today, 3:02 AM Thread Starter
canosoup
Thanks to all the helpful replies, have not got around to putting it on a lift yet but we will keep you posted on the findings with all the helpful tips!
